Hey guys, i've put a deposit down for an R33 GTS, manual
Now.. i'm from NSW and already have my Automatic Provisional License...
I got the line because, i would like to learn manual and then get my P's on a manual for assorted reasons...
I am curious... what are the laws regarding this...
Do i simply learn it, go to the RTA and take the manual test? Or are there some other complications?
I was speaking to a friend from VIC and he said down there after you have your Red P's (auto) you can't apply for a manual license until you have your full license..
But, i know in NSW after a year on your red P's, you're allowed to drive a manual regardless of whether or not you have a manual license..
The big issue for me here is, am i allowed to resit my test for a manual car after having already recieved my auto license? ( I haven't held my auto license for a year) :)
I have checked the RTA website.. but the information i have found is already known to me..
P1 licence, signified by a red P plate, is issued for 18 months
Be restricted to driving an automatic transmission car or clutchless manual (depending on the vehicle in which the DART is undertaken).
( I can't find anything saying you can't resit the DART )
Edited by ignuz
https://www.sau.com.au/forums/topic/95161-need-help-asap/
Basically i dislocated my shoulder 2 days before my Licencse test so I had to do it on an auto (Did it to my left arm) anyhow latter on when my shoulder was all better I did my test for the Manual. I had to re-do the driving test on a manual.............now im not sure if the R33 GTS is classified as a high performance 6 cylinder car...........if it is your not allowed to drive one under the new laws.
If you got your P's before the new laws came in then your fine otherwise your rooted.
And yes once you get onto your green P's they automatically give you the right to drive in a Manual anyhow.
This is the best of my knowledge as of 1 to 2 years ago........things may have changed since then........
https://www.sau.com.au/forums/topic/95161-need-help-asap/#findComment-1721919
thankyou very very much! :lol: yea i checked the banned 6 cylinder performance cars and a GTS isn't one.. :)
https://www.sau.com.au/forums/topic/95161-need-help-asap/#findComment-1722041
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
