Item:HKS OIL COOLER AND EARL OIL REMOTE AND BRAIDED LINE AND FITTING COMPLETE KIT FOR R32 GTR OR 33
Item Condition:USED
Reason for Selling:DONT NEEDED ANYMORE
Price and Payment Conditions:ASKING $700,COD,DIRECT OR PICK UP
Extra Info: THE KIT COME WITH COMPLETE LINE AND FITTING
Contact Details:LIST BELOW
Edited by dinzlr
Dinzlr sorry to post in your forsale theard but seen a pic of your engine bay the other day. Just after who made your airpod box and was it a one off all do they have others. How much as well
Thanks Brad
Edited by blk180
  • 1 month later...
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
