I have not had much luck with coolers on my 32 gts-t, the first HKS core was stolen from WSID. The second (Hybrid) last night was damaged when I hit a full grown wombat at 90km/h.
Rather than buying a new core is anyone able to tell me actually how much damage a FMIC take before you have to make it into an arty coffee table???
I don't have access to a digital camera but I will describe the damage.
10cm height, 7.5cm length positioned near the end tank.
In this area the fins are bent but the veins through the core have only indented about 5mm.
So to recap.....is this core still usable with some TLC, or does anyone know of a repair shop that will repair this damage......or should I just get a cheapie and cut my losses. Any advice will be welcomed. cheers Dan
RIP Walter the Wombat.
https://www.sau.com.au/forums/topic/95479-intercooler-repair/
Intercoolers cant take that much damage dude....have u actually ran the car? is it still making as much power? id think it wouldnt be. Its not really an expensive area anymore as people like just jap get cores for $300 and there 650X300X75 i think, its up to u wat size.......id suggest replacing it mate
How long is a piece of string? you ask the question "...how much damage a FMIC take.." which is an imposible question to answer.
Intercoolers these days as Nathan has implied are so cheap these days that repairing them is really nonsensical.
Because they are so intricately constructed with thin walls and fine louvres for better heat transfer they are hard to repair properly.
I'd say if the cooler is leaking obviously it needs to be replaced. If its bent then thats really only cosmetic and therefor it'd be your call. If it has a large area of damage where the fins have been folded over and no longer flows air then the intercooler isn't doing its job and obviously due for replacement. It's a tedious job but you can straighten each individual fin/folded louvre with a fine tip like a seal pick or flat blade screwdriver.
Just use your common sense.
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
