Yesterday, whilst driving my car and stopping at the lights, ocasioanlly the car would get into a sort of "rev Spasm".... It would drop revs almost to zero on the verge of stalling, then bounce back up to 1200rpm, and this would cycle over and over until I iether switched if the engine and started up again, or nursed the Idle( very hard to get idle back to normal by accelarating)
My AFM hasnt ever been playing up, however i am going to clean this tomorrow...
Is there anything else which can cause this? will the AAC Valve, be having an effect?
I also noticed on my boost gauge as it was trying to recover idle, the vacuum pressure would should up all the way up to zero, perhaps a little under. Which seems extremely wierd to me? does this signify a vacuum leak allong the lines somewhere??
Any help apreciated
https://www.sau.com.au/forums/topic/95562-rough-idle/
before i got my car tuned my car did this, way to stop it havin a spazz, was to rev it so you got boost and vent the bov, and then it stoped serging, but it was really gay because at a set of lights you look like a tool reving ya car ahahah spechly if theres some shit hot car next to ya.... but thats how i solved my serge before i got the safc and tune so yeah....
https://www.sau.com.au/forums/topic/95562-rough-idle/#findComment-1729646
I had the exact same problem yesterday, but it went away once I turned the air conditioner off.
It was really strange as the car drove fine with the air con on for about 5 mins, then it started to idle really rough and drove like a dog. Once I turned the air con off and gave the car a few small revs, it seemed to rectify the problem and the car drove fine again. I thought perhaps it was a bit of bad fuel or something, but when I drove the car later in the day with the air con on again, it did the same thing again.
Car's going back to the workshop this week for a few other things, so I'll be getting my mechanic to have a look at it for me while it's there.
Anyone got any idea what may be causing this?
https://www.sau.com.au/forums/topic/95562-rough-idle/#findComment-1729662
Cleaning your MAF meter should help. If switching the car off and then on again fixes the problem I would point towards a faulty MAF meter. Try other things like cleaning the throttle body and AAC valve at the same time and see if these help.
https://www.sau.com.au/forums/topic/95562-rough-idle/#findComment-1730646
Mine started doing this revving thing when i got my power fc installed
drives perfectly, but at idle just does this stupid down to 500 then to 1100 and yeah keeps going
it does look pretty stupid when ppl look at ya and they think you doing it. i just want to put the window down and say its the car ,
im takin it back to fist at wacol and they are going to have a look at it
let yas know what it is, if they do fix it.
Also on wednesday i turned my car off and when i went to turn it back on again, it just made a click sound and didnt start i had to wait abit till it would start again, a bit weird, but hopefully that will be sorted out too
and i went down the quarter last wednesday and the check warning light for the engine came on when the car is under load.
I'll post back on wednesday
THanks
https://www.sau.com.au/forums/topic/95562-rough-idle/#findComment-1730772
Sorta. An AFM is an Air Flow Meter and measures Air Flow via air flap and needle.
A MAF meter is a Mass Air Flow Meter and measure Air Mass via hotwire.
They both virtually do the same thing and essentially achieve the same results but through different methods.
https://www.sau.com.au/forums/topic/95562-rough-idle/#findComment-1730960
Yeah i have my car do that idle thing too.
Ive noticed its always on a hot and muggy day that when i start the car its idle rate will go up and down and some times even stall . But it seems to iron it self out after it gets running for a bit.
I will have to check my MAF. Good to hear that my car isn't the only one :D
https://www.sau.com.au/forums/topic/95562-rough-idle/#findComment-1736351
i went to fist
had the hand controller hooked up on the car
idle was put up to 900 instead of 850
some base setting was low and , didnt catch the other thing he said
but it was high, so he made it so it equalled out .
i drove it tonight , seems to go pretty good , havent noticed the idle go whacko yet but let yas know .
I'll try and find out what the things on the hand controller exactly were
i think i might have to get one,
https://www.sau.com.au/forums/topic/95562-rough-idle/#findComment-1736465
Hi Guys,
I had the problem a few months ago, not s much at idle but always before turbo's kicked in, it would cut out and gve a sharp jerk, its been fixed, the problem was that there was excess oil inthe airflow metres, got cleaned out, and works fine, but if the problem continues its time to replace air flow meters.
https://www.sau.com.au/forums/topic/95562-rough-idle/#findComment-1748766
Check your thottle position sensor. Tap it with a soft mallet while its running to check it's connections and internals are ok. Mine was fine when adjusted, but acted up after 5 minutes driving and drove all jerky and misfired and crap.
https://www.sau.com.au/forums/topic/95562-rough-idle/#findComment-1770880
Another thing you could try is check your alternator is putting out the correct voltage. Make sure you check it at the terminal on the back of the alt...not just at the battery. If your output voltage is low eg...11.80V, the battery light will still not come on but the fuel pump and ignition may not have enough to run them properly as the computer will only see about 9.5-10V of that.
Your problem is probably elsewhere but it doesn't hurt to check as it will cause idle probs.
https://www.sau.com.au/forums/topic/95562-rough-idle/#findComment-1772701
any way it could be an Idle port prolem on ur throttle body? it can have trouble switching from air going through the throttle body, to it switching totally to the idle port. If it gets blocked up with gunk or carbon it can make that car act a bit like that at times or eventually make the car stall. just a thought.
https://www.sau.com.au/forums/topic/95562-rough-idle/#findComment-1772866
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
