i think its just the rev limiter cause it just sorta doesn't really go or change gear for a little while after it happens and it doesn't always happen just sometimes. My speed sensor on my gearbox is a bit dodgey i think so may be a bit of a problem with that. Ill make sure its rev limiters tnite when i drive it again
  • Replies 101
Mine was just a single 1 piece dump/front pipe with a 3 inch catco cat and 80mm cat back with 2 mufflers.
The wastegate couldn't be leaking after getting a knock in the post could it?
good point, i should pay more attention.
When you run less boost does it come on boost earlier? I'm just thinking about the stock rubber intake pipe sucking closed. Also, what sort of filter are you running?
i dono have not tried it will give it a shot later,although i don't want to loose the boost setting atm as can be a bit of amission to get it set back right. i would not have though it would be sucking closed. its a Apexi pod filter also i have a right angle bend for the pod so it sits a bit further away from the engine as is closer to the outside air intake but i dont think this would matter either
thats the filter i have http://www.modyourcar.com.au/product_info....roducts_id=2604
I think it is that
4 of the best Tuners in perth told me it was
A) plug gaps
B) rev limeter
C) fuel cut
I used to have a blead valve and could not adjust boost properly but now i can adjust ot .3 of a psi
So C) was the correct 1 but only after they checked my gaps and tryed to run more boost looking for hp
i tune it my self with the help of turbo smart
if we have a cruz i will show you wat i mean
changed my whole out look on moding my auto
james
The pod shouldn't cause problems. They are one of the best flowing on the market. The pipes do suck in if they are a bit old and you are running a bit of boost, though it would have been spotted on the dyno i'd expect
Was not boost controler more the boost it self
i found the eboost2 very easy to work very precice
soo i could fine tune the controler and no dyno needed 4 that
just turn off the car start it and change boost settings from the cabin
and it a very acuate boost gauge as well some thing i through was a waste of time
how wrong i was
i have tuned mine so well i flat stick it and no more pops and more power cause engine is firing and ecu can handle it
best $915 i spent
james
yeah depends a bit on the dyno though as well some read pritty high. I have never heard of hyperdrive reading high seems they are quiet acurate. Do you have a manaul and rb25 though?
I am going to Mayhems thursday he is gona have a bit of a look he doesn't seem to think its right either
I have power and hold button on the auto umnm i think the computer learns
Edited by AntonRx7
yeah cause it takes a bit of time for it to change gears sometimes so would make it a bit slower. Boost seems to fluctuate up and down at the end of the rev range a bit as well as i have recorded it on my defi gauge dono if that is just from bouncing of the limiter. I will see if it does it tnite as i am not 100% sure if its is the limit. Either way still has got nothin to do with why its low on hp
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
