The gravity of those steaks and pancakes just pull cars toward it. They must be good.
hey is that an SAU hat i see? the guy with the grey shirt? is he reading this now?
Translation of rest of thread "someone crashed their car what a doody head, ill never crash my car im a l337 driver uleh.............my water dish is empty"
Going on by another forum apparently plates were 2TIMER, if thats the case I remember seeing this car & it was an asian driver, so possibly he was just trying to park :D.
LMAO
On a serious note... At least there's another 5speed RB25DET box around. :(
Edited by Cubes
That'll buff right out.
haha
sorry guys someone had to say it.
seriously though what a dick. He is really lucky no one was hurt. And yes that little stunt will most probably make the terrible police sentiment towards skyline drivers worse.
Thats effin great eh , another numbnut with a nice car f%$kin it up for us what an idiot for all the places to do it in the city. No wonder the cops are crackin down , I reckon ppl should be screened before they receive the keys to skylines. i wonder if he got grilled by the cops.
my car looks just like it, i had cops looking at me last nite when i was driving through hindly st...lol
Come summer, if you drive down those two streets you will most definintely be defected.
They have setup defect stations at the end of rundle for many years, for the 11 years that I know of at least. :(
Occasionally you see a defect station down Anzac also, much easier to get around them on Anzac, not rundle and hindley though. :)
Edited by Cubes
They have setup defect stations at the end of rundle for many years, for the 11 years that I know of at least. :P
Occasionally you see a defect station down Anzac also, much easier to get around them on Anzac, not rundle and hindley though. :P
Not to forget the defect station they generally put down te bay also!!!
as i said he over cooked it in second whilst attempting a slide!!
kept power on , hit the gutter got air bourne smashed into the wall and back followed, there fore wedging it in...
what a waste, should know not to do it there and how to handle your car.
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
