This is my thread for the things I find out as my engine gets rebuilt.
I blew the ringland between the 2nd and 3rd rings in no.6. All the other pistons were pitted etc.
The rods are indeed the same as GTR rods (anyone want to buy the set I bought in case they weren't :))
It appears that the head uses quite a different design than previous RB25's. More details to come.
It uses a RB26 style oil pump but retains the short drive on the crank like early RB26's and all RB25's so I'm going to try to source a Jun crank collar.
At this stage I'm thinking of 8.8:1 compression ratio to give me a bit of safety with the tune but hopefully not losing too much in the way of response or power. I've had everything from 8.2 to 9+ recommended to me which has been confusing.
Removing the engine wasn't too hard with the help of Duncan and Ed. Thanks guys.
I think that's it for now.
https://www.sau.com.au/forums/topic/95854-my-rebuild-and-what-ive-found-out/
  • Replies 183
Stock compression wasn't measured.
Blew it - http://www.skylinesaustralia.com/forums/in...topic=87738&hl=
Can't rely on the availability of Optimax 100 just yet.
Bass junky with the same setup to what I will have (ie cams and turbo) could only put 0.9 bar into his engine but got great power there so I thought that with a little less compression I might be able to squeeze in the extra boost to make up for lower CR plus a little more for happy days.
Some pics to come.
I spoke to GCG today about my turbo maxing out at 14 psi.
He said that he's never heard of one making that power at that boost.
He said they were most efficient at about 17 - 18 psi.
I'll get to the bottom of this. Maybe RacePace are just the worlds best tuners.......
Abobob,
Its definitely a concern, go with an 8.5:1 to be safe. :D
On that note I believe Freebaggin is still running the stock 9:1, he hasnt mentioned the use of a thicker headgasket.
He's running an internal gate .6 something GT3040R. I remember back when it was first fitted, ~270rwkw on 17psi, he has since fitted 256duration cams and cracked 300rwkw. Its not on an optimistic dyno either.
It's not a NEO. Maybe the Neo has some issues with cam timing or something silly? I'm not 100% sure on the NEO VCT, is it constantly variable or??
Edited by Cubes
I will be fitting the Tomei Tybe B Poncams which are 260 degrees both sides and 9.15 lift. This will lower my dynamic compression ratio a little and hopefully make it a little more resistant to detonation.
I don't know anything about the VCT. As for cam timing, all I know is that adjustable cam gears have been proven not to work on the NEO.
Bass - maybe GCG are making better turbos than they think because I had 228 at 0.85 bar, no cams and auto. One dyno operator reckoned that was close to 250 in a manual although I think the R34 auto seems to be a less lossy transmission than some. It makes me wonder if Sydneykids GTT had a turbo with different specs (ie GCG are doing them different nowadays) or that it had a thicker head gasket in place before he saw it because with the same cams it takes an extra 0.5 bar to make not that much extra power.
And let's not forget the reputable workshop who told me not to expect more than 220 at the limit of the turbo. Methinks some people have an agenda.
Here are some photos my engine builder sent me last night.
Agenda? Definently.
SK's 265rwkw figure was recorded in Shootout mode which at 250rwkw reportedly gives about 10-15 rwkw higher figure.
Until the next dyno day on a shootout dyno, I'll not know what my car makes in shootout.
I have the same cams Abo Bob.
Here's my power curve.... It's fat.
Agenda?  Definently.
Thats a nice curve, must be pretty damn quick on the street.
So you guys really rate the GCG hi-flow as the best option for the 34GTT? I have an auto as well and probably chasing 250rwkw for the time being. How much extra kw will this turbo give just by itself :D I'm currently on about 200 so I don't know. If it's a long way off, I might as well get a different turbo.
    • Even with the piston at TDC there was room for it to drop, but I don't think it can drop fully into the cylinder, the problem you have is that you need something pushing against the valve to hold it up so you have enough room to put the new stem seal on and the spring etc.  I used compressed air only because putting rope in the cylinder seemed a bit risky to me, I know people have done it countless times before like this. Overall it's a pain in the ass job. Honestly you'd probably be better off taking the head off because the risk of dropping something in the engine and the finicky-ness of it all is very stressful. If you are going to attempt it though i 10000% recommend a 36050 valve spring/keeper tool. I had both the traditional lever type and after doing 1 cylinder it was absolute pain to get those valve keepers in place, even with 2 people. That 36050 is amazing, you do have to push hard to get them in place but it works perfectly almost every time. Back to my actual issue I think my engine is just tired and old and the rings have gone bad. The comp numbers (cold, no oil) were: Cyl 1 -129psi Cyl 2 - 133psi Cyl 3 - 138psi Cyl 4 - 137psi Cyl 5 - 157psi Cyl 6 - 142psi   Cylinder 5 and 6 having the most carbon on them.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
