  • Replies 183
OK so a GCG hi-flow would be good for up to about 250rwkw... after a decent tune. I'm assuming that the SAFCII won't be good enough for tuning purposes?
So for all supporting mods:
1 x hi flo turbo or similiar
1 x new fuel pump
1 x adjustable fule reg
1 x new management system???
Would you guys reccomend getting new injectors or would the R34 stock injectors be good for 250rwkw?
Stan
Why wouldnt a SAFC be up to the job? For the supporting mods Im looking at using the SITC / SAFC combo, with stnd injectors, bosch pump and nismo regulator..... wanting 200awkw from non-neo Rb25.
......... why I can confidently say that Shoot Out mode doesn't ALWAYS give higher power readings. Well, not on our dyno anyway
lol I found that funny! man, what Id give to have a dyno in MY garage (at home, not work). :lol:
Brendan
Basically because SAFC will only do fuel and air control? There is no timing control option in that... hence why I said it's probably not the best option.
I'm running 200rwkw at the moment, just gathering information for the big jump :P Hopeful that I can get it all done with $5k
Thats right, so grab a Apexi SITC (super ignition timing converter), fairly rare now but I found a brand new one for $220US on ebay. Being installed right....about....NOW!
:P
Brendan
well i just got off the phone with my tuner and my car is going in on friday to get the emanage ultimate fitted. All this talk of power has made me antsy. I dont think the ultimate needs the ignition signal adapter like the older version does, but i iwll soon find out. As for the zener diodes i think that i will put them in anyways, just waitning for and email from 666DAN. NO one else has a wiring diagram for the inclusion of zenners in the ingintion wiring do they?
Am looking into it right about now :P
Anyone else know if this thing will work?
Satan,
See Stagea section, Gary's thread (SK) Apexi Super Ignition Timing Computer, he reckons its all good, and thats good enough for me by far.
Mine is going on the Stagea right now (yesterday / today), with high pressure fuel lines, nismo adjustable fuel pressure regulator, bosch 040 fuel pump, and a z32 afm.
Getting it all ready for the turbo upgrade, hopefully I dont need larger injectors........
worth a look maybe, start on ebay. :lol:
Brendan
powerplay quoted me $1600 for rom tuning. that is a fkn joke. considering it needs to be done everytime you do more mods. Emanage ultimate with all harness(even car specific harness) and greddy e01 ebc cost me $1600. If rom tuning was cheap it would be a good option, but they want ridiculous amounts to do it.
Isn't there a Daughterboard you can buy through a group buy here that allows you to modify the stock rom form your laptop......
Was quite cheap too I beleive.
Dr Drift can tune them.
I was wondering how long it wopould take for SK to see this.
Any further thoughts on my 250rwkw ceiling SK?
14psi, very conservative timing......
Id say Race Paces dyno is very very generous. 250rwkw at 14psi when its not even in the turbos effeceint range sounds a little too high. Considering you can pump another 5psi and easily get another 20-30rwkw. i went from 17-20psi and i picked up 13rwkw and at least 30rwkw in the middle with a 2535. Silva33 got 244rwkw on 14psi with a 2535 on the same dyno. Put another 5psi in that we are looking at 270rwkw, i just cant see that from a 2535. Considering i only am getting 231rwkw at 19psi from a 2535 from a dyno dynamics dyno in shootout mode. It may read low but thats all i got. Tuning for max power isnt too hard, get the A/F ratios in the high 11's and some good timing in her. Watch the knock, if its too high bring out some timing, its not too hard. Unless you are running no timing, your still going to produce some good numbers. Good tuning is in the light/middle throttle which takes alot of time and effort.
Unfortunately those dyno sheets dont show the setup of how the dyno was run. Dynos can quite easily be enhanced.
Nah, RacePace is one of the best in the country.
He doesn't play with the numbers because most of the people going there aren't worried about numbers. Just getting the best from their cars.
Ash's R31/RB25DET ran 20rwkw higher in Shootout mode on the same dyno, and it's known to be conservative.
I'm not even into the efficient range of the GCG.  14psi is quote low.
but dont forget GCG probably are rating @ a stock head style setup
non cams, and are they counting the fact itrs a NEO in thier info for you?
I had a little run with Silvas 244Rwkw (14psi) with my old 2530 setup and basically it wasnt as close as what it should have been
driver.
youve been racing yours @ the strip for a while now remember
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
