Edit: Assembled interfaces available from caz here: http://www.skylinesaustralia.com/forums/in...howtopic=109498
Group Buy over - thanks to everyone who took part!
Edit: Its very important that you do not connect the cable directly to your laptop - it MUST go thru the interface box. Not sure what it would break, if anything if you hooked it up directly, but i dont want to be the one to find out either.
Edit2: Given caz has a group buy for $105 for usb cables, it would make sense for anyone with usb only on their laptop to get a cable from there (unless you already have a usb->serial converter), given converters are 10$ and up.
Following on from the Diy Consult Interface Kit, my brother is assembling some of these for those who are confident, or dont have the time/equipment to assemble them themselves.
Please refer to the other thread for all other background information - the only difference between the kit and the assembled interface is the price, and it obviously comes pre-assembled.
At this stage, 8 pre-made interfaces are/will be available.
Cost: $70, which includes express post ($72 for paypal, but it's instant)
Ordering and Payment: PM me to order
Payment is available via bank deposit or paypal only:
For paypal, this incurs a $2 fee, total being $72. Payment can made by logging into paypal, and choosing "send money", sending to my email (right click copy shortcut, then paste into the address field when sending money, obviously removing the mailto:). If your address in paypal is right and you choose send address option, then ill have everything i need to send out the interface, but a quick pm with a copy paste of all details would be good. You should ensure theres a confirmed interface available before you do so (else postage obviously cant occur until one is completed).
Make sure a postage address has been supplied. Normally express post items need to be received but no signature (otherwise picked up from post office). Areas outside express post network wont arrive the next day. See list at end of post for previous/pending purchases. I'll keep this updated with the status of all orders. If you do not wish your details (SAU username or email if no SAU username supplied) or the express post parcel number to be displayed in this thread, then let me know.
Already have/dont want consult plug/pins?:
If you already have the consult plug/pins, or do not wish to get them with the interface (to save more money), then i can supply the interface minus the consult plug and pins (just wires on end of cable) for $55 ($56.70 for paypal). I wont, however, be able to provide any help for you to wire this up to your car's connector or however you wish to go about connecting it. Given the kit is made so that you can disconnect the box from the cable that goes to consult port, you could wire it directly to the pins on the ECU, but again this would be you're own responsibility.
List of purchases:
1. Nightcrawler - sent 23/11/2005, MN6508936
2. lbfalcon - sent 25/11/2005, MN6508940
3. FAT32 - sent 28/11/2005, MN6508939
4. CoolPC - sent 05/12/2005, MN5834546
5. RR 84 WA - sent 6/12/2005, MN5834547
6. Osman R32 - sent 8/12/2005, MN5834548
7. linksys76 - sent 13/12/2005, MN5834549
8. MerlinTheHapyPig - sent 14/12/2004, MN5834550
Contact:
PM or Email
Peter
Edited by NewKleer
https://www.sau.com.au/forums/topic/95948-assembled-consult-interface/
mine arrived today - not even 24 hours after I ordered it. Amazing service mate - it works a treat!!!!
Is there any way you can make them USB? My lappie does not have a serial port and I had to buy a $40 serial to USB converter :P
not as easy to find a casing for a usb one (even the box for this one wasnt easy to find), so i wouldnt hold out for one
usb/serial converters are only ~15$ on ebay, and a usb version of this would cost at least extra that id guess (prob 20-25$ more)
check out caz group buy for usb interfaces - if you have a usb only laptop, theres no point getting one from me while that group buy is running
Edited by NewKleer
ah fair enough - I should have use my brain and organised the purchase of a converter better, but as you know I wanted to use it urgently to try to diagnose my problem. Thanks for your help!
just a reminder to everyone that u must not connect the cable directly to pc (otherwise the box that comes with it would be useless wouldnt it :) ) as this can break stuff i assume
just a reminder to everyone that u must not connect the cable directly to pc (otherwise the box that comes with it would be useless wouldnt it :P ) as this can break stuff i assume
This is a one peice cable correct
Lee
no, its a cable + box as pic in diy thread showed (ive attached it here now)
having it box + cable means to "turn it off" all u need to do is disconnect the cable from the box - u dont have to unplug it from the consult port near fusebox like one piece ones. so you can permanently mount the cable, and just connect the box up when you're using it.
btw, i sent yours out just now, express post number MN6508940
Hi Peter,
Thanks for the fast service ! Just got some Q's.
From the black junction box to the laptop I now need a cable to connect. Is there any special requirement for a cable to get ?
Also is it OK that one of the plug connectors on the black junction box is lose ? ( moves around in the black box )
Sorry for asking dumbass questions but this stuff is foreign to me :D
Cheers.
the cable supplied goes into one side of the box. the other side, as long as your laptop doesnt have some weird obstructions near the serial port, will plug directly into the serial port (ie, u have the box pluggest directly into serial port).
if this isnt possible, then a normal db9 serial extension will be fine (it will need to be female-male/male-female, not male-male or female-female)
there will be a slight movement of either or both connectors on the end up and down/side to side, as there box isnt manufactured exactly to hold the connectors without movement, so this isnt a problem (it could be glued to keep it stable, but then u couldnt open it if u ever had to)
how long will this be running? i will be interested after christmas for sure.
until all sold - currently up to position 7 or 8 are in process of being made, not sure about anymore after that
Edited by NewKleer
just received money for last assembled interface, this group buy is now over (a few more diy kits left though), thanks to everyone who took part.
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
