Group Buy: Cb Radios (updated - Dec 23)
  • Replies 255
cool.
if anyone cant make it to the BBQ on december 4th please let me know, cause if i have them by then and you cant make it then i will need to organsie shipping or another time to pick em up
nope... i think i put in the first post they can be organised seperately through jaycar along with the batteries cause the batteries are much cheaper through jaycar.
1. Abusd - main unit. cig charger. normal charger. batteries (Possibly up to 3 sets)
2. Dezz - main unit. cig charger. normal charger. batteries
3. West- unit, normal charger, batt
4. West- unit, normal charger, batt
5. West- unit, normal charger, batt
6. Ferni
7. Mavric - main unit. cig charger. normal charger. batteries
8. Saff_cossie - main unit, cig charger, normal charger, batteries
9. Jackie - Main unit, Cig charger, normal charger, batteries
10. Freddy Kruger - main unit. cig charger. normal charger. batteries
11. Tracid - cig charger. normal charger. batteries
12. Frunkmont-unit,batterieis,normal charger
6. Ferni
13. missrb25det - mainunit, charger, batt
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
