just a quick question... am i right in saying that if u have an safcII u no longer need an afm??? or am i completely wrong.. as i tihnk i have read this somehwere... as the safcII will control all ur air flow readings thus no longer needing the afm... if so wat would i be better off purchasing.. an safcII or a z32 afm??? cheers JT
https://www.sau.com.au/forums/topic/96051-safcii-or-z32afm/
to use a z32 afm you need safc or aftermarket ecu or remapped ecu.
z32 is only required for 250rwkw and this is due to voltage restriction and not "size" restriction as the z32 is the same opening diameter as the stock rb25 unit.
your car will not run as a good and wont be as driveable with a map sensor setup if thats what you are thinking of. you need an aftermarket ecu that supports map sensor to get rid of the afm, such as motec, powerfc djetro, microtech
https://www.sau.com.au/forums/topic/96051-safcii-or-z32afm/#findComment-1739291
yeh alot more power... just reseearching now but eventually... btw greg.. im in need of another cooler off ya man :) are u able to post them out or pick up only?
I'd go with the Z32 and get the stocky ECU chipped or get Power FC.
$175 for a cooler delivered within Vic.
PM me or email me.
cheers,
Greg
https://www.sau.com.au/forums/topic/96051-safcii-or-z32afm/#findComment-1739295
Do both mate! Grab a 2ndhand Z32afm from these forums for $200 or so, and a new SAFC II, and have them tuned at the same time.
I found at 141awkw my rb25 afm was reading near max volatges on the safce, so having it retuned today for a Z32 afm.
Brendan
https://www.sau.com.au/forums/topic/96051-safcii-or-z32afm/#findComment-1739889
There is no way an RB25 AFM is maxed @ 140rwkw.
Everyone does 190rwkw which is the limit of the turbo (give or take)... there is still more in the AFM
Dont get a 2nd hand AFM anyway, not worth the hassle if it starts playing up.
Which, after 10 years is highly likely
https://www.sau.com.au/forums/topic/96051-safcii-or-z32afm/#findComment-1740669
R31, after the tune at 141 All-Wheel kw the voltage on the stock rb25 afm is 4.95Volts, I was told 5.06 (or 5.16 by memory?) was max.
The tuners said if I want more power, then with the next mods a Z32 afm was needed, so I found a good condition 2ndhand unit and its being retuned right now along with other parts.
I just hope it works!!!
https://www.sau.com.au/forums/topic/96051-safcii-or-z32afm/#findComment-1740704
Ive got a March 1997 Nissan Stagea RS Four V, automatic, with 4wd attessa system. RB25DET has done 82000kms and replaced timing belts etc, at 80000kms along with major service and mods.
All parts have been installed now, just the SAFC needs a tune, tomorrow. Ashley at Graham West Workshops (Marion, Sth Australia) has cleaned the Z32 AFM with contact cleaner, and said it works just fine and is in good condition (luckily!! I was worried after your post about not buying 2ndhand Z32's afm's due to wear / tear).
Here's a list if you're intrested R31Nismoid (Ash?):
Dayz special edition Stagea RS V Four
Clarion stereo tape unit with 6-stack cd player
Clarion amp
Clarion subwoofer
Pioneer 260w front door speakers
Eclipse 80w rear door speakers
New Oxygen sensor
Bosch 040 fuel pump with direct battery feed at 13.8volts
New high pressure fuel lines
Nismo adjustable fuel pressure regulator
Nissan Z32 Air Flow Meter
3inch JustJap stainless steel single dump pipe system
3inch Catco high flow catalytic converter
3inch Dayz edition cat-back exhaust system with quiet muffler, all in aluminium coated mild steel
K&N pod filter in custom enclosure, replacing soon with BMC panel airfilter and standard airbox
Apexi 'hybrid' front mount intercooler with custom pipe kit
Hybrid dual stage Electronic Boost Controller, set to 10 & 12psi (after this current tune)
Apexi boost gauge
Apexi SAFC Super Air Fuel Computer
Apexi SITC Super Ignition Timing Computer
Future mods: Hiflow RB25 turbocharger, Front DBA slotted rotors, Front braided brake lines, and lastly a Full suspension kit with most parts from the Group Buy
Cheers, Brendan (see SA section for details on my REAL beast, the Fireblade!) :rolleyes::D
Edited by bwilkeson
https://www.sau.com.au/forums/topic/96051-safcii-or-z32afm/#findComment-1741383
AFM's are funny things sometimes, when for $200 (or less) more you can get a brand newie... thats what i would do personally.
Sometimes you can get great 2nd hand gear is you know where it comes from :rolleyes:
Hmm... 140 still seems waay low for an RB25 AFM to max out at without a though. Interesting!
https://www.sau.com.au/forums/topic/96051-safcii-or-z32afm/#findComment-1741391
Cheers mate, I thought newbies (Z32 afm's) were around $400? I couldnt find a 2ndhand one for less than $150US (on ebay, I know you dont like it!). Where are they for $200? Id buy one new for that price for sure!
Yeah, I was very surprised at the dyno report, AFM near maxed out, injectors at 76% duty cycle, good a/f map at 12.0:1, 141.3 AWKW.
So, Ive done the Z32 and doing the FPR / fuel pump / fuel lines to help out the injector flow (hopefully)..... getting it all ready anyways for the high flow turbo (got a 2ndhand one sitting at home, was meant to be a Neo but it isnt.... )
Looking for around 200awkw+ with the hiflow, eventually.
Brendan
https://www.sau.com.au/forums/topic/96051-safcii-or-z32afm/#findComment-1741403
:P
Cheers..... yah, eventually, just on a 'tight' budget at this stage(a). (sorry, bad joke)
This time next year when the hiflow happens, might look into a new Z32 AFM, depends on how the current one is holding up.
Looking forward to picking up the Stagea from the shop tommorrow to see how the tune affects the car. Cant wait....
https://www.sau.com.au/forums/topic/96051-safcii-or-z32afm/#findComment-1741412
    • Either the WG is reaching full opening, or it is not. The "it is not" case could only occur if there was not enough time available to swing the valve fully open during that boost event. I would consider that to be unlikely, as this is a commercial product that is in use elsewhere, so it really should work. But in your case, because there is definitely SOMETHING wrong, it should not be assumed that things like that are working as they should. You should put a video camera where it can see the actuator (if at all possible) during a run to see how far it is moving.
    • I think you're mostly on the ball there. With the straight gate, I suspect the weight of the spring will determine how quickly the gate can close, when not run with active pressure drive on both sides of the diaphragm. Otherwise, with drive on both sides of the diaphragm, you could almost go without a spring at all, only needing one to make sure that the thing was actually closed while completely off boost and not having pressure available to drive it closed. Butterfly valves have mostly symmetric loading when there is flow going through them, meaning that the gas hitting the upstream part of the blade is balanced by the gas hitting the downstream part of the blade, which means you don't need actuator torque to overcome any non-symmetric flow induced loads. But the gas flow does impart a purely normal load against the shaft, which transfers into the bush/bearing at each end of the shaft and does increase the torque required to make the shaft turn. Only a little, but it is there. I have no feeling for the amount of force involved in a WG application, but it certainly could make an argument for a decent spring weight being required. But all of this is just peripheral to the actual problem here.
    • The answer to this would be I followed the documentation from Turbosmart which said each spring pressure could achieve a maximum of 5x it's rated pressure so the included smallest spring being the 6psi had a range up to 30psi. I went with the 12 because I figured it'd likely hover around 15psi as a base pressure however I was obviously wrong.    I have a log here that I'll dig out that is purely wastegate and no Mac valve controlling anything.   If it can't hold anywhere near 12psi, does that mean the straight gate is virtually wide open during a run? Or am I thinking about this all wrong.   I could Tee Piece into the cooler pipe pre intercooler where the wastegate gets its feed, and send that to the ecu and see how that reads, I just don't have a spare pressure sensor currently that's all.
    • lol nice, I wouldn't worry about sanding back the filler to check for rust then. Yep very much a thing. Personally I don't do the panel beating, its very easy to have a panel beater sort that out for you. If they aren't doing any prep work the actual panel beating generally doesn't take long at all.  Have you taken before pictures before you started this project? I'd be keen to see the before and afters when you're done.
    • Some good discussion in here, for the most part I can't really add too much to it - thought I'd add some notes to the datalog screen shot that probably aren't news to anyone but a good prop... this is assuming 25psi-ish should be the boost ceiling given the first post refers to 23psi.   To state the obvious, this issue seems super weird.  Turbo speed seems pretty lethagic to build, like the turbo isn't getting as much drive as it needs - and it doesn't help that wgdc keeps rising AFTER boost target then completely shuts duty at a point, which in theory should have the straight gate dump heaps past the turbo and funnily enough causes the huge drop off.  It seems like pretty blunt boost control tuning but I'd not call that the primary issue, so much as possibly not helping the situation. I'm curious, what does a pull look like with purely mechanical boost control?  Like purely wastegate?   There are things in this log and story that make it sound like there could be a significant restriction in the intercooler piping or something - but then it's also overshooting boost target which is NOT what you'd expect with a restriction.   I can see where people are coming from with the non-linear wastegate bypass (not that any valves are linear for this kind of thing), but it still doesn't make sense that it can't hold <20psi on a 12psi spring.    Have you, or can you try measuring pressure pre-intercooler?  Be pretty interesting to see what's happening there vs in the intake manifold - sorry if I've repeated old ground, I've kinda skimmed over but I could have missed something.  In terms of comments regarding the wg spring being closer to boost target, I haven't used a straight gate but part of the reason for having close to wg target is about fighting backpressure as well - I might be wrong, but I'd have thought that part of the point of using a butterfly valve like the straight gate does you actually don't have to resist pressure at all, on EITHER side of the gate.   It shouldn't need too much leverage to start opening, the spring being more to do with where it triggers opening as opposed to resisting boost & EMAP, though smarter people can correct me if I'm wrong there.
