Hi I am cleaning out my garage an I have the following parts for sale from my r33 I am located in Geelong which is near Melbourne.
Trust Front Bar (In ok condition needs some repairs) SOLD!
Series 2 Front Bar (In good condition with lights) SOLD!
GTR Grill (Has a small crack) SOLD!
17" Voltec Rims off my r33 Skyline (Rims in good condition with minimal scratches, Tread on tires is down near the wear indicator) SOLD!
17" HSV Senator Rims (They have some gutter scratches and minimal Tread) $550
16" HSV Clubsport Rims (Good gondition with a few scraches, good tires with about 80% Tread) $550
All items would be prefered pick up only and i can be contacted on 0424887758 or [email protected]
Edited by warby
Hi, how are you?
Would you have any pics of the Series 2 Front Bar and the 17" Voltec Rims?
I am in Sydney and may be able to come down to Melb, but at this stage not entirely sure. Would it be possible to arrange shipping to Sydney?
Regards
can you send me photosof both the trrust bar and series II bar?? with the trust bar does it fit perfect or are there gaps.
to [email protected]
Edited by skyline33
Are the rims still for sale, and can I please have some sizes?
will be coming to Melb in the next few weeks, but can arrange payment earlier if you need.
  • 4 weeks later...
Hey buddy was wondering if you have any front body parts for sale like front and rear reinforcer (metal behind the bumper), condensor, horn, radiator support, bonnet catch etc...
If you do please email me at [email protected] and attach your phone number
thanks!
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
