Nissan 180sx CA18det AUTO.
Chrome wheels.
5" exhuast.
BOV.
Car runs perfectly fine, does not blow smoke, etc etc.
but the car has right hand side damage.
door was hit, 1/4 panel was hit and door sill was hit, and winscreen is cracked.
door has now been replaced so all u need is the other parts.
the roof hasnt been creased or anything and the sunroof glass is still all perfect.
$2500 firm car has to go, wil now ship at buyers expence, no tyre kickers.
call me on 0428234489 or 0434585196
email. [email protected]
Edited by WillWillWill
https://www.sau.com.au/forums/topic/96135-nissan-180sx-2500-running/
Hi Will.
Few quick ones please mate:
From squinting at the pics, it looks like a digital dash with the HUD. Is that right?
Is the car actually driveable or is the sill damage keep the door from closing?
Actually, would you mind PMing over your phone number? Alternatively, I can send my number if you like. Probably faster than lots of q's over the net. Thank you mate.
Mark
i'm interested.
how much would it cost to ship to melbourne?
and general parts prices?
i'm assuming you were going to fix it and decided not to...
correct me if i'm wrong.
i'm interested.
Dude, in as polite as possible voice, those prices are your job to find out. The man has said what needs fixing. It's now up to you (and me) to do the ring around and see what bits cost what - don't wait around for a good deal to fall in your lap, go out and chase it! :(
You know what is broken. Ring a painter and grab a quick quote on replacing a sill. Ask him about painting a door and a fender. Look at the trims that need replacing. See if you can find a Nissan windscreen (because it looks like it has the HUD). Ring a few trucking/shipping companies and see what their backloading prices are like. Add all of that up, plus your time and effort, and see what figure you come up with. THEN you go back to the seller and negotiate their price so that it is worthwhile for you.
You could even see if it is worth wrecking. Had it been a 2L, I daresay yes, even just for the engine. Anyway, sorry about the long post, but you've got to do your own homework. :)
yea and also,
u dont need a genuine windscreen, yes u wuld because it has the tint for the HUD.
but a genuine windscreen is about 900 so u can just get a normal glass company to do it for roughly 250 and get a tinting specialist to do that little patch for about 50bux :( gona save u alot of money
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
