no havent organised anything as yet. but will probably go check it out anyway. is there a cruise tomorrow? my clutch is playing up a bit as i just got the motor tuned properly on a dyno, now it slip[s in second like no tomorrow. dont wont to get stranded anywhere. will replace clutch before going on cruises in the future as i am just puttin around at the moment. any suggestions clutch wise?? im pretty sure mine is standard so a brass button heavy duty should keep me happy for a while. :)
Edited by HR-32
https://www.sau.com.au/forums/topic/96251-new-member/#findComment-1746677
no havent organised anything as yet. but will probably go check it out anyway. is there a cruise tomorrow? my clutch is playing up a bit as i just got the motor tuned properly on a dyno, now it slip[s in second like no tomorrow. dont wont to get stranded anywhere. will replace clutch before going on cruises in the future as i am just puttin around at the moment. any suggestions clutch wise?? im pretty sure mine is standard so a brass button heavy duty should keep me happy for a while. :angry:
i got the same problem, mine slips like crazy 2nd n upwards. started after the midnight cruise. im getting a heavy duty installed by my local mechanic, around $600, he put in a heavy duty on my old r33 gts 2 yrs ago an it was heaps good. i got prices at like other mechanics (ultra tune, midas, etc) n they all say clost to a grand. the only bad thing is ive had 2 wait 2 weeks cos he is busy, n now its getting done on thursday so i cant wait, cos i got a boost controller and i havent got a chance 2 use it yet haha
https://www.sau.com.au/forums/topic/96251-new-member/#findComment-1747302
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
