most of the time when i quick shift from 1st to 2nd gear i can feel the gears crunching together, but you dont hear much of a crunching.but if i gear down e.g- from 4th to 2nd it never crunches.
if im driving normally from 1st to 2nd it doesn't crunch at all.
recently did a gear box oil change using standard oil, and was doing it before oil change.
would it be my 2nd gear syncros.
i heard mayb using redline oil may help..
anyone got any suggestions....cheers
https://www.sau.com.au/forums/topic/96264-crunching/
Hi mate...
I've got similar problems...
I've got an R33 RB25DEt and I love it.. My transmission is fine at slow changes and quick shifting but as soon as I get over about 120km/h... whenever I change gears... the teeth grind...
I've been told the syncros are half stuffed.. I don't really know much about transmissions so if anyone else can shed some light on the subject, that'd be great.. I could reccommend changing your oil as well... get some good oil this time..
https://www.sau.com.au/forums/topic/96264-crunching/#findComment-1745175
Redline or use some slick50 treatment. Or Nulon. I think Slick is the best. Couldhelp reduce the problem. Since you have already replaced the oil I would buy a ttreatment of some sort...siphon out a little gearbox oil and add the treatment. Drive for 1000kms see if it gets better...If not - take out a little bit more and add another additive...
Not sure if it will be bad to mix but the box doesnt sound thmuch good anyway...
Redline is more just a decent gear oil - I think the traeatments have more of a chance of working.
Edited by benl1981
https://www.sau.com.au/forums/topic/96264-crunching/#findComment-1745471
I just changed the oils in my r33 gtr to redline synthetics and the gearbox is alot smoother however I am now getting a clunking noise in reverse that is amplified by this oil. I have been told the noise is normal though but it is anoying.
Would recomend it though as it was stiff through the gears before and had a it of a whirring sound coming from the drivetrain that has significantly been reduced.
sb..
https://www.sau.com.au/forums/topic/96264-crunching/#findComment-1749978
i changed my gear box oil to reline synthetic. so far ive driven 150 k's after changing the oil. changing into 2nd doesn't grind and crunch anymore, and the gear shifting has gone smoother. I did not adjust my slave cylinder as the mechanic said i only needed to adjust it if it was crunchin in every gear. So far so good.
Thanks for the help!
https://www.sau.com.au/forums/topic/96264-crunching/#findComment-1753137
I had synchro issues with 2nd & 4th gears..
Changed to Redline Lightweight Shockproof, synchro issues resolved.
I would rather try a $130 high grade oil first than get my box pulled down and the synchro's replaced.
Hmmm let me see which is it $130 or $1500 for parts and labour getting the box pulled apart..
https://www.sau.com.au/forums/topic/96264-crunching/#findComment-1756664
    • I found a supplier for an arm in NZ. https://thrashgaragenz.com/products/nissan-skyline-v35-z33-350z-front-lower-straight-arm-rh-side?srsltid=AfmBOopMdfCFDc_8yVZZ9kq5nIngPHRTBzUU8v4SAptJaRO52Wjs0bC6 I looked closely at the photo of that one and the Z1 arm, and it's the same bloody arm. Scratches all match in the photo 😂 How hard is it to change that joint? Also they seem to be listing two options https://thrashgaragenz.com/products/nissan-skyline-v35-z33-350z-front-lower-straight-arm-balljoint-rh-side?_pos=1&_sid=229acde44&_ss=r And now I have no idea what size I'd need yay
    • Ill review it again, from memory when I first saw some of Trailer Park Boys I wasn't a huge fan. I ended up at Letter Kenny after watching Shoresy, which is a bit ass backward, ha ha
    • "lol dunno" either But like you, I can't see any reason they would need to be different LHD to RHD
    • I agree with you WRT the hard top. MX5's may be one of the better looking soft tops but I cannot think of ANY car, EVER that looks better with a soft top vs a hard top (or a designed roof). At all, ever. I also feel this way about the C5 Vette, the Z06 looks horrible compared to it's original form, it has an exaggerated version of the differences you're talking about.
    • Hey crew, Failed my WOF cause of a lower control arm, and I've decided to hit both arms, and also the compression rods at the same time(seems they're gonna be the most likely upcoming failure points from some discussions with the lads over on the G35 reddit). I've looking at these form Z1:  https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-compression-rod-p-40716.html https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-lower-control-arm-p-40674.html I asked Z1 if they'd work as it's the same platform, just RHD vs LHD. I basically got told "Lol dunno". Specifically they aren't aware of any difference but can't guarantee fitment as they haven't done it on a 350GT. So guess I'm asking is if there is any issues with using 2005 G35 coupe suspension parts on a 2005 350GT coupe? Orginally I thought it could be something in the way of the arms that each control arm is designed to be positioned around, but that'd be an engineering nightmare for Nissan needing two different shaped control arms 😅
