most of the time when i quick shift from 1st to 2nd gear i can feel the gears crunching together, but you dont hear much of a crunching.but if i gear down e.g- from 4th to 2nd it never crunches.
if im driving normally from 1st to 2nd it doesn't crunch at all.
recently did a gear box oil change using standard oil, and was doing it before oil change.
would it be my 2nd gear syncros.
i heard mayb using redline oil may help..
anyone got any suggestions....cheers
https://www.sau.com.au/forums/topic/96264-crunching/
Hi mate...
I've got similar problems...
I've got an R33 RB25DEt and I love it.. My transmission is fine at slow changes and quick shifting but as soon as I get over about 120km/h... whenever I change gears... the teeth grind...
I've been told the syncros are half stuffed.. I don't really know much about transmissions so if anyone else can shed some light on the subject, that'd be great.. I could reccommend changing your oil as well... get some good oil this time..
https://www.sau.com.au/forums/topic/96264-crunching/#findComment-1745175
Redline or use some slick50 treatment. Or Nulon. I think Slick is the best. Couldhelp reduce the problem. Since you have already replaced the oil I would buy a ttreatment of some sort...siphon out a little gearbox oil and add the treatment. Drive for 1000kms see if it gets better...If not - take out a little bit more and add another additive...
Not sure if it will be bad to mix but the box doesnt sound thmuch good anyway...
Redline is more just a decent gear oil - I think the traeatments have more of a chance of working.
Edited by benl1981
https://www.sau.com.au/forums/topic/96264-crunching/#findComment-1745471
I just changed the oils in my r33 gtr to redline synthetics and the gearbox is alot smoother however I am now getting a clunking noise in reverse that is amplified by this oil. I have been told the noise is normal though but it is anoying.
Would recomend it though as it was stiff through the gears before and had a it of a whirring sound coming from the drivetrain that has significantly been reduced.
sb..
https://www.sau.com.au/forums/topic/96264-crunching/#findComment-1749978
i changed my gear box oil to reline synthetic. so far ive driven 150 k's after changing the oil. changing into 2nd doesn't grind and crunch anymore, and the gear shifting has gone smoother. I did not adjust my slave cylinder as the mechanic said i only needed to adjust it if it was crunchin in every gear. So far so good.
Thanks for the help!
https://www.sau.com.au/forums/topic/96264-crunching/#findComment-1753137
I had synchro issues with 2nd & 4th gears..
Changed to Redline Lightweight Shockproof, synchro issues resolved.
I would rather try a $130 high grade oil first than get my box pulled down and the synchro's replaced.
Hmmm let me see which is it $130 or $1500 for parts and labour getting the box pulled apart..
https://www.sau.com.au/forums/topic/96264-crunching/#findComment-1756664
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
    • Haha I just finished the last season of TPB: Jail last month. I'm happy they're still pumping out episodes.
