they usually hear the V8 (it quite loud as I've got only 1 straight through muffler on a 2 1/2inch system). Then they look behind the volvo, then to the side and then in their rear vision mirror. After that they have this WTF expression. This is the point at which I rev the engine.
When they lose its like they have been diagnosed with cancer look. ;)
  • Replies 42
Poor old volvo's a little bit sick... well the auto is.
Didn't like the burnout the other night, I got as much smoke off the auto as the tyres. Now it slips a little under big throttle and if held smokes it up.
An example is how I lost (just) to an MR2 turbo (red), I don't know whether this car was actually fast (my experience is they aren't) but the auto didn't like me even though I only used 'D' and shifted at 4000rpm.
Rev i think i saw you and the beast at Marlows Balcatta yesterday. Either that or there is another V8 Volvo around that is exactly the same colour. It looked sweet, and sounded unusual for a volvo especially when you where giving it a bit of stick when you left
thats mine.
It's back there now getting some work done on it (cooling system pressure flush) and the valve body on the trans looked at.
I only gave it a little throttle, when it gets 'a bit of stick' it screams quite a supprise if it's next to you on the road and it drops back a gear.
  • 3 weeks later...
I've just spent a whole day fixing oil, trans and fuel leaks on the 308 and turb 350. Gotta hate the dead heads who designed these things. I'm sure it will leak again in 6 months.
It's running pretty well again, poor old series VI turbo rx7 beaten by a volvo wagon :P:) :)
baby,
I hate to say it but the small block reving out to 6000rpm sounds alot better than a turbo screaming.
Turbo's just don't sound anywhere near as mean.
You might get a chance to see the wagon and see/hear what I mean.
    • Thanks mate, couldn't find in VIC, ended up ordering one from NSW, getting rwc to get new plates and registration done.
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
