yeh he run a 7.92@256
and backed off from what ive heard he didnt even get into top gear
another lil whisper ive heard is that hes developing a 2.8 to slot into it
so should be interesting :D
heres the clip if youre interested
http://media.putfile.com/Reece-McGregor-R3...-256kmh-14-mile
I doubt that he didn't get into top gear. I hate it when a car does a great time and then people say, "it wasn't on full boost", "the clutch was slipping" or it missed a gear".
excuse if i seem rude but please quiet in the cheap seats and shut up.
i was there and i saw the run in person so believe me when i say he didnt get into top gear and he did back off.
and was far from a perfect run.
to be perfectly honest i was dumfounded when i saw 7.92 on the board as i thought it didnt look as fast as sum of his previous 8 second runs.
The man himself said he didn't get into top gear - they don't have a reputation of talking shit (maybe this is common in Oz???).... 256kph trap speed when they usually run 270+ is an obvious sign. Apparently they are working on what went wrong with the box with the intent of running tomorrow. I guess that will clear some stuff up??
They've already done an 8.033 @ 172mph already - so no matter what way you look at it, a solid seven second pass is inevitable... if not now, with the new motor.
The car has already run a 7.9@162MPH (backing off).
