Holy crappolla, so sorry, shaft broken. Usually you find that sort of damage when you have loose objects in the inlet. I don't believe that just happened instantly, it has been building for a while. Maybe out of balance for some time due to a small hit. I would check out the inlet system very carefully, make sure there is none left to do it again. That's painful.
:) cheers :)
OK guys, job done.
All bits back on the car and it is running, but it seems to be producing a lot less power and doesn't feel anywhere near as strong when it comes on boost. This leads me to believe that the old (stuffed) turbo was quite possibly running higher than standard boost, which may have lead to its early(?) destruction. Time to get a boost gauge, me thinks! Where to mount it and keep it looking stealthy, I'll have to figure out. Maybe I'll try and source a series II three-gauge DIN display.
There was (and still is, despite my best efforts to remove it) some evidence of something being stuck to the dash on the passenger's side. Who knows, maybe it had previously had an AVC-R or similar (but it was fairly big, roughly the size of an AVC-R or SAF-C) stuck down in that spot with double-sided tape.
With this in mind, I'm wondering if maybe the wastegate actuator spring might have been changed at some stage in a previous life. Can anyone (SK, maybe?) measure the spring rate on the actuator (compared to a standard one) if I bring the old turbo over to them? I just want to get an idea if this could be the cause of the problems...
I took the intercooler off and gave it a flush too, and getting those pipes back on was a bit of a bitch, especially when it came to lining up the clamps and then, later, putting the airbox back on. I found lots of little fragments of the compressor wheel in the intercooler too, but nothing in any of the intercooler pipes or anywhere leading up to the throttle body, so hopefully I got rid of all of it.
Thanks again to all for your input!
Nick T.
OK guys, job done.
Nick T.
Hi Nick, I didn't know you had no boost gauge and a sticky mess on dash, sure sign of a modified past. Any turbo shop can measure the wastegate actuator, but first I would check the vacuum hoses. Look for signs of them being changed or modified, clamp marks, cuts, no restrictor etc. It is easy to swap the hoses around and get 7 psi all the time via bypassing the solenoid, have a look in the DFA IEBC thread for pictures.
If you are sending the turbo off to them to get it high flowed, GCG will check the wastegate actuator.
:D cheers :)
:) cheers ;)
Thanks SK, I'll do that. I didn't take real notice while we were working on the car, but there's no obvious evidence of cut hoses, etc. I might have to take another look and see what I find.
I'll have a look at the DFA/IEBC thread too and make sure everything is as it should be, and maybe do some testing by bypassing the solenoid as you suggested, then change it back and compare.
Did anyone notice the differing numbers on the compressor housings? My old one has "45V4" on it, and the replacement has "45V3" cast into it. Also, when I found the bits of compressor wheel, they didn't look anything like steel to me! Maybe it's an R34/Series II Neo turbo, who knows? Looked kinda like plastic bits, and the parts were very light for their size, broken or not. Did they have ceramic turbines too? Can't be bothered doing a search at this hour.
I will get the turbo rebuilt and hi-flowed (and actuator checked), as soon as the budget allows. I might try start saving to get it done ASAP, just in case I start to have more problems with the replacement, as it's a high-kilometre unit. Then of course all of the support systems (fuel pump, injectors, FMIC, computer, etc.) will need upgrading too. which may take a while. I was gonna start putting money away towards the stereo first (essential!), and then after that suspension upgrade and some nice wheels, we'll see how it all goes. Might need to find myself another (more enjoyable) job with better pay, or start a small biz of my own, or something - I dunno...
In the mean time, does anyone know where I can source the 3-gauge DIN-sized cluster like in the series II Stageas (and similar to GT-Rs)? I might ring Just Jap anyway, but if anyone spots one, please let me know. I would have liked the Defi DIN cluster, but it doesn't include a boost gauge (despite the fact it's big dollars). Instead it has one pressure and two temp gauges in it.
These are the Defi clusters:
Rang JustJap, and they don't have any Stagea clusters (and can't remember ever having one), and they don't know if the GT-R one would be the same because they've never been able to compare them...
SK, can you shine any light on this question, by any chance?
Oh, and as far as the cluster goes, JustJap make a 3-gauge DIN fitting so you can install three 2" gauges of your choice. I'll most likely do this, with a boost gauge, and oil temp and pressure gauges. I'll also probably still get Defi units, as they make them in this size.
Thanks in advance once again.
Nick T.
Thanks Brendan. I had a look and am still a bit confused. My cousin's R33 is a series 1, and it had steel compressor wheels, so hopefully that side of it won't be an issue. I'll still keep the boost at standard for now - even though I miss that extra little bit of power it seemed to have - it'll save me blowing the turbine again too.
Rang JustJap the other day and they don't have the DIN-holder in stock at the moment, and probably won't have any until roughly mid-late January... I might do what some others have done and get a bit of aluminium cut and painted for the gauges when I get them.
Reeeeeeeeally need to replace the stereo soon, firstly because I've blown the standard speakers, secondly because the CD player skips over even some minor bumps, and thirdly because it's a double-DIN unit, so I need a new single-DIN unit to have somewhere to put the gauges.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
