Hey guys
just showing the dyno results of when i got my power fc installed and tuned at fist last month.
set on 10 psi roughly
power fc Ap Engineering
FMIC
CES RAcing split dump
Hiflow 3 inch cat
3" exhaust
Tell us if anything doesn't look right
It does seem to be pretty smooth to drive
I have also noticed that, sometimes when i get in the car to start it has the clickin sound but doesnt start
wait for a bit then starts
im thinking it could be my battery, or coils or something don't know
seems alright at the moment, and voltage has been on 14.1 when driving.
THanks
https://www.sau.com.au/forums/topic/96641-dyno-result-from-fist/
needs to be done on the dyno unfortunately, they connect a sensor to the exhaust to take the readings. I am not 100% sure but i would imagine they would lean it out by removing fuel from the map cells. U could do this yourself with the hand controller but not recommended as u will have no idea when it becomes too lean.
Where did u get it tuned?
powerfc, batmbl dump pipe and hiflo cat, r33 gtr cooler, straight though 3" exhaust (made 30rwkw with this exhaust over the blitz i had before), powerfc boost controller, pod, custom plenum
exhaust has taken a bit of getting use to, especially with the blitz jobby before being not much louder than stock
truth be told, i love how she sounds now
slightly droney, but have decent sound system in car that doesnt make it an issue
did a run down to stanthorpe with full load and passengers never complained once, so cant be too bad
yer, i was happy with mercury
initial tune was 162rwkw with the old exhaust which i was pretty disappointed with
but more than happy now
plan is to high flow the stocko turbo when it falls appart or when i save the cash
wifey has to drive the car and its our daily driver, so cant go too crazy
i got it tuned at FIST
but was thinking of checking out matty spry at the gold coast as heard  good news from him .
And i dont have a hand controller with my power fc, might have to get one .
What mods have you got spooks ?
Good idea to go see another tuner :O From memory matty actually has some real qualifications. I dont thing anyone else really does.
Also try 101 motorcafe.
sounds good spooks, i'm hiflowing the stocker aswell in the future
i'll see how the car goes for the time being
but next tune will be definately be with another mob .
see how they go
might do fuel pump next, get it out of the way.
Thanks for the help
Let yas know how the next tuner goes.
hi fella,
i get my 33 tuned by chiptorque on the gold coast (where matt spry used to work)
they are awesome. lachy the owner really knows the power fc unit well and i heard he got fc edit and datalogit which should save you some cash come dyno time. my 33 has a fmic, power fc and 3/4 exhaust and pulled 185.3rkw with solid afr of 12.1.
cant wait to get back on the dyno for a retune now with cam gears, full pump, reg and ces dump pipe fitted. hopefully should see 200rkw on stock turbo.
just giving you another option come tune time.
cheers glenn
Baz, comparing it side by side with spooks graph it is a good result.
You got 187 and he got 192rwkw. A 5kw margin.
Both have similar mods except you have 2 psi less boost, AFR is 1.2 lower and you have a street exhaust (cat).
Oh, and the inlet temps on his are 44 as opposed to 22. Not sure what the equation is but pretty sure if yours read 44 you might have even seen higher than him.
At the end of the day, dyno charts are holding less and less credibility as time goes past so take it with a grain of salt.
Nice result.
By those readings on my dyno chart
would it class as being a safe reading ???
cause with afr's and inlet temps, wouldnt have a clue of what a optimum level it should be at, to be the most effecient and power.
Would it be worth while gettin my car tuned again as soon as i can
cause too me my car seems to be running quite smooth
But have noticed ( not frequently) the engine warning light flicker while under load)
not sure if its just the power fc learning ( if it does or not)
or timing is just so far advanced
THanks for your comment FATGTS-R
Barret
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
