IMMACULATE 1996 NISSAN SKYLINE R33 GTS-T SERIES 2
70’000KM’S
Rego to 9/2/07
ENGINE
rb25det
5 speed manual
gfb boost controller
HKS Super Dragger II exhaust 3.5in (Turbo back) 5in tip
HKS Sqv bov
Heavy duty clutch
Apexi power intake pod filter, I also have the stock air box if needed
INTERIOR:
Quik trak alarm
Apexi power fc and commander (tuned)
Autometer boost gauge
Momo shift knob
Turbo timer
Exterior:
GTR Adjustable rear wing
Series 2 "M-Spec" Front Lip Spoiler
Tinted windows
17in mags new front tyres 80% on rear
Sunroof
Very clean body no dents
Car was imported in febuary 2004 since then it has been Very well looked after. Drives
Handles and performs beautiful. Interior is in great condition looks very new The exterior is also in awesome condition, paintwork is great
Engine runs very smoothly, gearbox feels smooth
Serviced every 5000km’s
Asking $21,000
Contact: email [email protected]
Mob: 0402611674
post-18608-1133351420.jpgpost-18608-1133351661.jpgpost-18608-1133352220.jpgpost-18608-1133352415.jpgpost-18608-1137073206.jpg
Edited by Apexi R33
https://www.sau.com.au/forums/topic/96755-1996-silver-r33-gts-t-series-2/
  • 1 month later...
Good luck with the sale - I just sold my silver 1996 R33 Skyline SII (That looked exactly the same as yours!), and I also had AVS Mod 6 wheels / GTR wing (once again, the same wheels you have!) for $18.5k. You'd got a couple more mods (PFC), so you should get that price without too many dramas :P
Good luck!
Tommo.
hey mate,
what rims are they?
AVS Mod 6's :P I had the same on mine...
http://users.bigpond.net.au/m_thomas/tommoskyline.jpg
They look unreal.. you should buy the car :P
AVS Mod 6's :(  I had the same on mine...
They look unreal.. you should buy the car ;)
Thanks TommO they sure are AVS Mod 6's
that pic of your car is very similar looking to my ride.
except your rims are white or should i say were white. nice :)
  • 3 weeks later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
