Hi all, i've recently notice on late model R34GTR, they all have this little vent seem to sit on top of the turbos. Nissan has never had vents on their cars before havn't they?
Anyone know what's the purpose of this? It doesn't look like an air escape vent neither intake vent!!!
Also anyone has a close up pic, under the bonnet pic?
https://www.sau.com.au/forums/topic/96824-little-vent-on-r34gtr/
I can assure its not an aftermarket item its a stock Nissan item that all series 2 V-specs have . Try another dealer , one that deals with imports .
Alright, i've been on the phone with some of Nissan dealers for the last 2 hours :lol: , friday thing, dont' feel like working lol. Anyway, no one was able to find the article for the vent EVEN THOUGH it shown on their pdf sheet that there is a square HOLE on the bonnet!!!!
To be able to dig in further, i'll need a chassic number of an R34GTR. Well its' not that important, i'm just curious thats all. Garry Roger Nissan has been very helpfull, Also found part number for R32GTR Thermal switch (2159573L05) and cost $115+gst still they don't know what temp range it will activate the fan.
managed to get it working and yep its a trap for the shit that falls through the hole....Factory bonnets are painted and the quality is quite poo...you can still see the woven mesh throught the paint...they tape up the vent hole before painting them thats why it looks like a separate part.....Do you want one of these vents?I could hack one out of an old panel if you like
no.....its on the carbon bonnets only and its moulded into the bonnet......not a seprate parts
It is only on the c/f factory fitted bonnets ( all V-SpecII's have them ) but i'm fairly sure it comes off . Its not even painted the same colour as the bonnet .
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
