  • 11 months later...
anyone around my area on these forums with the blue r32 gtr with the jap stickers above the muffler (factory colour too!).
ive seen that car outside the w'bee plaza... it was with 2 other r33's before that big albert park cruise last year
this may not help, but i recently acquired a blue r33. i live in keilor.
So terrance had an R33 first... :D
So what happened to your GTR that wears a poo suit terrance?
did it dissapear up your very wide asshole ???
and R32 BEAST - dont go digging up old threads man.
it's seriously un-cool, this possibly is worth a locking as we now have our sightings thread
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
