Hi all, just putting the word out there that there is an r31club drag day on the 28th of january.
Its at the Ac Delco dragway in invermay
For all interested can you reply to this thread.
The cost at the moment is $80 but the more people that come the cheaper it will be
MEETUP: 9am Brighton bakehouse carpark, leave around 9:20-9:30am
Follow the white hr31 4 door pillarless gt for the cruise up
Can i please ask you all to STAY BEHIND ME ON THE CRUISE UP
There will be a camera in my car and i want footage of all the cars cruising behind me in a big line, if you dont wanna be in the footage or for some stupid reason dont wanna cruise with us feel free to speed on ahead
White HR31 to look out for:
Edited by project 500
https://www.sau.com.au/forums/topic/96877-r31-skyline-club-drag-day/
Ok mate, my mobile number is 0418 804 299
Gimme a call or sms and let me know about the payment if your entering
Grandmasterb: If you are keen on running dont let that stop you there will be a few people mate im sure youll know someone
Where?
Guys there is now a $5 spectator charge as fundrasing for prize money, ive talked with quite a few people about this and they think its a fair amount seeing as its gonna be a good day.
Also can i ask, if your in the pack cruising DONT SPEED or drift or try to make a name for yourself, it wont be tolerated.
Ahh........... this and that.
ppg dog box
o.s. R3C
T517Z 10cm
Greddy intake kit and dump pipes
260 tomei cams and Greddy cam gears
Apexi FMIC
Trust pipe kit
Apexi Power FC and RB20DET AFM's
And a little blue bottle... hehehe.
Thats about the bulk of it, oh and
a carbon bonett, 18x9.5 volk GTC face ones, coilovers, sparco seat and harness etc.
Best to date, 11.45@126mh on 12 psi and 1 stuffed turbo...
I got it stock from Japan about 10 months ago.
    • There are black hose clamps as well if you care. Plazmaman for example sells some: https://plazmaman.com/product/black-hose-clamps-premium-quality-stainless-breeze/
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
