Just a quick question....
My old man looks after a VL turbo IP car for his boss's son, they've done a couple of meetings now and it has a strange habit of pumping a shitload of oil into the catch tank, like 1.5 litres after practice.., doesn't appear to be blowby, more like oil retention in the top end?
Its an RB30ET, but is this a common RB thing?
Nothing adverse appears to be happening, its not like its built to really open clearances, the motor is fresh and new top to bottom. A few people who had worked on RB30ET's did mention it might be an issue...But I thought maybe if it is an issue which the DOHC ones share, people might have some ideas?
If its just a design issue in the oiling system of the RB30ET, fair enough. It doesn't seem to be causing any form of damage, its just annoying.
https://www.sau.com.au/forums/topic/97249-rb-oil-control/
Hi floody, After a day of Supersprinting I regularily empty out the contents of the catch can which is about 1 ltr. It is oil retention in the rocker covers. I spoke to Sydneykid about it previously and he explained that the RB engine has difficulty getting the oil back from the top end to the sump. He told me he fits an external drain and restricts oil to the cam covers, to help get the oil back quickly to the sump. Aparantly some Drag cars can fill 2 ltr catch cans over 1/4 mile.
Ian
https://www.sau.com.au/forums/topic/97249-rb-oil-control/#findComment-1764016
Ian
Ahh okay, I had a feeling that might be the case. Thanks for that, I'll let the old man know.
https://www.sau.com.au/forums/topic/97249-rb-oil-control/#findComment-1764379
is the sump baffeled? Like the trap door designs in sumps they use so you dont get oil surges or no oil pickup when going around a corner?
Yeah High Energy aftermarket baffled, big volume sump. Definitely not having cornering g-loading related oil surge problems.
https://www.sau.com.au/forums/topic/97249-rb-oil-control/#findComment-1764390
Ian
What Ian said......plus they need oil flow restrictors in the block (where the cylinder head joins). The oil pump (especially a high flow one) pumps too much oil at higher rpm for the drains to return the oil to the sump. Depending on the rpm you are using, you may need to block off 1 of the 2 oil feed holes and fit a restrictor in the other one.
:D cheers :D
https://www.sau.com.au/forums/topic/97249-rb-oil-control/#findComment-1764405
sydneykid, if i were to run a uprated pump on my little rb20 (such as a n1, nismo, trust, ect) would i have the same problem with too much oil going to the head?
when my motor was running i noticed it would throw some oil into the catch can but i suspected it to be the rings/pistons failing.........but perhaps it was also some of the oil vapours from revving so high (8k redline).
if so would putting a restictor in the head not cause oil starvation to they hydro lifters?
Edited by carl h
https://www.sau.com.au/forums/topic/97249-rb-oil-control/#findComment-1766954
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
