full article click here
http://www.dpsmotorsport.com.au/dps/viewtopic.php?t=52
well done Stace and "twoogle"
to keeping track of "twoogle" can be done at
Edited by DiRTgarage
Congrats Stacwy and Paul.
Glad to see the Skylines still cleaning up the trophies :D
Thanks Dave, went there to use the car to premote the Sport Compact Drag Series. Came away with some nice trophys and a headache from the "doof" all weekend.
Good work :)
No king of airbrush trophy? :D
lol...some peoples definition of automotive art is a tacky mural sprayed on their car....mine is a hand crafted manifold etc....
Never a truer word has been spoken..... err written..... ahh you get it.
Quite possibly the funniest quote I've read on these forums :)
Congrats guys.
And I'm really glad to see Stacey won the Driver With Attitude award. She really was the friendliest person I spoke to at the shows. Most people just fob you off when you try and take interest in their cars.
Well done!
Congrats guys.
Well done!
Thanks Monkey...will catch up on the 18th at the Point 2 Point.
Congrats  :)
We were there late Saturday to have a bit of a look, must have been one of the few times you guys were not with the car  ;) I'm sure we'll see you at WSID soon.
yeah, late Saturday afternoon had to go to Croydon to get the other two drag tyres to try on the dyno....an experiment that failed due to lack of tyre pressure.
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
