The gearbox should be good for about 500hp, after that your living on borrowed time. There are some replacement gear sets, or you could nitride your gears to give them extra strength. Anything more than 500hp will severly push the limits of the drivetrain.
See'ya:burnout:
https://www.sau.com.au/forums/topic/9736-which-rods/page/3/#findComment-165600
  • Replies 53
You will definately need a decent clutch, the driveline should be fine as long as you are not into hard launches, which I assume you are not into if you are chasing bottom end and a nice wide torque curve.
The only reason I say the rb25de head instead of the rb25det is that the det has vvt on the inlet, and if you want torque, your best off getting cam gears, therefore de head rather than det.
Something else to think about - if you get head and block, you can get the work done - which will take weeks- while your car is on the road. To fit the 3040, you will need a custom manifold and wastegate and a new dump pipe - so the stock one wont be of much use to you. Ultimately, being stuck with a whole heap of parts isnt much use to you - IMHO it would be alot easier to sell the old motor as compete as possible, you could even take a prospective buyer for a test drive and let a mechanic check it out, then when the other engine is ready, swap them over.
I am absolutely not saying that you need to use the rb25de head instead of the rb25det, just some food for thought
steve
https://www.sau.com.au/forums/topic/9736-which-rods/page/3/#findComment-165702
The rb25de head has slightly more aggressive cams, and although they would be replaced in the end they might be a bit better in the short term.
500rwhp, but hard lauches with slicks will kill it sooner than that. A minimum of a twin-plate clutch will be needed.
See'ya:burnout:
https://www.sau.com.au/forums/topic/9736-which-rods/page/3/#findComment-165708
hahaha... thank Merli. I've got an OS Twin in there now and it's sweet. Don't know if i should delve into the RB30 block. At the end of the day i'll be up for some $$$ doing the clutch and gearbox all the time. I might do the Skyline up nicely and get a buzz box like an RX3 or R100 13B Turbo.
With the oil galleries on the RB25DET head, are they the ones for Variable Cam Timing? Is that worth keeping for the trouble of doing all the welding and drilling etc?
Thanks Steve, i'm on there now having a look!
Andrew
https://www.sau.com.au/forums/topic/9736-which-rods/page/3/#findComment-166028
Merli,
I have the same feeling about the triples, great if your never going to drive the car on the street, but useless if you are. My OS twin is sprung and is very easy to drive, but twins will still take a pounding, but I think I'd rather repair it than drive with a triple.
See'ya:burnout:
https://www.sau.com.au/forums/topic/9736-which-rods/page/3/#findComment-166075
Merli, your not the first guy I have heard making similar comments about triple plate v's twin. Hoping I never have to go down that path.
GTS-t VSPEC, I think that one of the gtrs SST have built with approx 540hp (at the wheels?) uses a hks twin plate, but that is a circuit car - spose it depends on how hard you drop the thing off the mark, have you tried to 'drive' off the line like they do with huge hp gtrs? I'm working on that myself, and if you get it right you can get off the line very quickly - even a bit easier to control wheel spin. Might save you a box rebuild too, once the hp starts rising further? I am currently running a 9 button ceramic ferride with 2500lb pressure plate and at 203rwkw havent had the slightest sign of slippage (probably a bit early) - hope it holds on a little longer......
https://www.sau.com.au/forums/topic/9736-which-rods/page/3/#findComment-166128
Steve,
For the drags I have been slipping the clutch rather than dropping it, it is the slipping which kills them. I know the car you are talking about, and agree that a twin is ample in most cases, even if it need the occasional rebuild.
See'ya:burnout:
https://www.sau.com.au/forums/topic/9736-which-rods/page/3/#findComment-166553
  • 3 months later...
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
