If anyone has bought a "pre-fabricated" exhaust system for their ceffi, could you post up what brand and size etc, maybe even a picture? :)
OR... does the Ceffi have a "sister" car that an exhaust system will be able to match from?? for example: S13 coil overs fit to A31 Cefiro....
Thanks.
https://www.sau.com.au/forums/topic/97448-cefiro-exhaust/
I would say you could pretty much use a R32 exhaust if you just change the mounts. The recesses in the floorpan however I think are fairly standard.
That's only a guess though. - your best bet is to drive to a wrecker or something and get a r32 one and just place it under the car to have a look and be prepared to weld some mount points.
Otherwise someone more knowledgable than me could probably comment too :)
https://www.sau.com.au/forums/topic/97448-cefiro-exhaust/#findComment-1768125
R32 and cef aren't interchangable. Cef are different to most other nissans due to the placement of the spare wheel
I just made myself an exhaust. Problem solved
Also the reason you cant have the muffler on a big angle :D
https://www.sau.com.au/forums/topic/97448-cefiro-exhaust/#findComment-1772206
  • 4 months later...
