Item: 1993 r32 gts-t nissan skyline
Website:http://carpoint.ninemsn.com.au/UsedCarID=850154&TabID=3328&Alias=carpointau
Item Condition: excellent
Reason for Selling: want track car
Price and Payment Conditions: $15,500 without rims 17,000 with. cash, bank cheque
Extra Info: 4" hks exhaust, boost gauge, turbo timer, 18" rtg shadow rims, full respray, full kit etc.
Contact Details: mark 0411 138 677
Edited by driftr32
https://www.sau.com.au/forums/topic/97599-cheap-1993-r32-gtst-must-sell/
I'f you want the full list go to carpoint I have more pics and listed everyting on it the price is at 18,000 on there but dont worrie about that I just haven't changed it yet. and I'm not going to strip the car down to make it affordable sorry dude there the prices take it or leave it. what are you looking at spending any way.
  • 1 month later...
kms, mods and mech condition? Ha stiming belt been done etc etc. Kms per tank of fuel and current boost it is running. I am waiting for sale of my car before I can look any further but am hugely keen on something like yours Mark. Thanks.
  • 3 weeks later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
