can u make a r32 gtr skyline 100% rear wheel drive but still have 4wd at a flick of a botton i no u can pull a fuse or somthin out and make it like 80% rear wheel but just wanna no if this can be done and for how much u think and would u be able to still have it as a every day driver
Edited by overboost
https://www.sau.com.au/forums/topic/97961-r32-gtr/
Send a PM to 'Duncan' and see if he has more ATTESSA controllers for sale.
And if you're after help, cut the sms talk dude. There is no saving in typing 'no' instead of 'know'. It just makes it hard to read and pisses people off. Also try breaking your post up into bite size chunks commonly known as sentences. Cheers.
https://www.sau.com.au/forums/topic/97961-r32-gtr/#findComment-1779132
pulling the fuse makes it 100% rear wheel drive until you refit the fuse.
you can make your car 2wd while driving along in 4wd. step 1, put your foot on the clutch while driving, step 2, turn the ignition off while your foots still on the clutch, step 3, turn ignition back on and foot off the clutch, now you will be in 2wd without having to pull the fuse out. to ensure your in 2wd the orange 4wd light will be lit on the dash. please note that this is only possible on the R32 GTR's. the car will automatically go back into 4wd mode when you bring the car to a complete stop.
hope some of you lucky GTR owners have learnt something new, happy sliding... B)
Edited by gtrgodzilla
https://www.sau.com.au/forums/topic/97961-r32-gtr/#findComment-1779600
You can get a torque splitter than will do the job as well.
Dude refer post #2. That's what an ATTESSA controller is.
Overboost, yep, they can adjust it to your liking, from max split to no split. The search engine will turn up all the answers. :)
Heath I hope you've been behaving yourself mate! :) hehehe :blink:
https://www.sau.com.au/forums/topic/97961-r32-gtr/#findComment-1780266
The ATTESSA system in the R32 GTR is pretty good for its torque-split-ness. I notice it only kicks in (that is, the front torque guage shows a reading) when I launch hard from a standing stop or I go over slight bump on the freeway etc.
It will never have more than 50% of the drive at the front wheels anyway and to get that you wouldn't have time to notice what the guage is reading as you adjust the awesome slide you are in :)
https://www.sau.com.au/forums/topic/97961-r32-gtr/#findComment-1783190
Just for those that aren't aware, the torque split gauge does not measure a percentage, it measures kilogram.metres, ie torque.
A reading of 50 on the gauge does not mean you're driving an overweight STi :D
That said, when your GTR rolled out of the factory years ago with its claimed 353Nm. That's around 36kgm, so a stock car won't see 50
https://www.sau.com.au/forums/topic/97961-r32-gtr/#findComment-1784364
Yeah, happy sliding for me too yesterday then a bit of a drift around the corner, then the backend broke loose and more oversteer, then I put a bit more throttle in to get the front torque to pull me straight but...
Round I went 180 degrees, parallel crashing into the 30cm high kerb on the other side of the road.
Damn it sucks crashing and f*#king up your wheels, suspension arms front lip and spoiler, and throw in a front crossmember and cv joint too. Only happened yesterday arvo Just out of lithgow heading back to sydney.
My fault, going too quick around a corner.
Take it easy guys.
https://www.sau.com.au/forums/topic/97961-r32-gtr/#findComment-1784425
Damn Sean! I saw your car for the first time last week too! Well as long as you're alright mate.
I had a 'moment' coming down Hawkesbury Rd a fortnight ago on a Friday morning when the road was greasy. I was trying to suss out how the torque split works and I did a similar thing but *just* retained control (it was a 35kmh left into a 25kmh right I think). Learned a good lesson! No damage, never connected with anything but enough to speed up the ticker for a few k's.
If you're after parts, let me know, cause I bought a stack (bumper etc) when I had my car painted and have a fair idea of how much Nissan can sell them for.
Mark
https://www.sau.com.au/forums/topic/97961-r32-gtr/#findComment-1788062
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
