can u make a r32 gtr skyline 100% rear wheel drive but still have 4wd at a flick of a botton i no u can pull a fuse or somthin out and make it like 80% rear wheel but just wanna no if this can be done and for how much u think and would u be able to still have it as a every day driver
Edited by overboost
https://www.sau.com.au/forums/topic/97961-r32-gtr/
Send a PM to 'Duncan' and see if he has more ATTESSA controllers for sale.
And if you're after help, cut the sms talk dude. There is no saving in typing 'no' instead of 'know'. It just makes it hard to read and pisses people off. Also try breaking your post up into bite size chunks commonly known as sentences. Cheers.
https://www.sau.com.au/forums/topic/97961-r32-gtr/#findComment-1779132
pulling the fuse makes it 100% rear wheel drive until you refit the fuse.
you can make your car 2wd while driving along in 4wd. step 1, put your foot on the clutch while driving, step 2, turn the ignition off while your foots still on the clutch, step 3, turn ignition back on and foot off the clutch, now you will be in 2wd without having to pull the fuse out. to ensure your in 2wd the orange 4wd light will be lit on the dash. please note that this is only possible on the R32 GTR's. the car will automatically go back into 4wd mode when you bring the car to a complete stop.
hope some of you lucky GTR owners have learnt something new, happy sliding... B)
Edited by gtrgodzilla
https://www.sau.com.au/forums/topic/97961-r32-gtr/#findComment-1779600
You can get a torque splitter than will do the job as well.
Dude refer post #2. That's what an ATTESSA controller is.
Overboost, yep, they can adjust it to your liking, from max split to no split. The search engine will turn up all the answers. :)
Heath I hope you've been behaving yourself mate! :) hehehe :blink:
https://www.sau.com.au/forums/topic/97961-r32-gtr/#findComment-1780266
The ATTESSA system in the R32 GTR is pretty good for its torque-split-ness. I notice it only kicks in (that is, the front torque guage shows a reading) when I launch hard from a standing stop or I go over slight bump on the freeway etc.
It will never have more than 50% of the drive at the front wheels anyway and to get that you wouldn't have time to notice what the guage is reading as you adjust the awesome slide you are in :)
https://www.sau.com.au/forums/topic/97961-r32-gtr/#findComment-1783190
Just for those that aren't aware, the torque split gauge does not measure a percentage, it measures kilogram.metres, ie torque.
A reading of 50 on the gauge does not mean you're driving an overweight STi :D
That said, when your GTR rolled out of the factory years ago with its claimed 353Nm. That's around 36kgm, so a stock car won't see 50
https://www.sau.com.au/forums/topic/97961-r32-gtr/#findComment-1784364
Yeah, happy sliding for me too yesterday then a bit of a drift around the corner, then the backend broke loose and more oversteer, then I put a bit more throttle in to get the front torque to pull me straight but...
Round I went 180 degrees, parallel crashing into the 30cm high kerb on the other side of the road.
Damn it sucks crashing and f*#king up your wheels, suspension arms front lip and spoiler, and throw in a front crossmember and cv joint too. Only happened yesterday arvo Just out of lithgow heading back to sydney.
My fault, going too quick around a corner.
Take it easy guys.
https://www.sau.com.au/forums/topic/97961-r32-gtr/#findComment-1784425
Damn Sean! I saw your car for the first time last week too! Well as long as you're alright mate.
I had a 'moment' coming down Hawkesbury Rd a fortnight ago on a Friday morning when the road was greasy. I was trying to suss out how the torque split works and I did a similar thing but *just* retained control (it was a 35kmh left into a 25kmh right I think). Learned a good lesson! No damage, never connected with anything but enough to speed up the ticker for a few k's.
If you're after parts, let me know, cause I bought a stack (bumper etc) when I had my car painted and have a fair idea of how much Nissan can sell them for.
Mark
https://www.sau.com.au/forums/topic/97961-r32-gtr/#findComment-1788062
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
