hey everyone.
in the near future im looking at heading to regency for my roadworthy compliance for my 32gtst...
ive got all the instructions and stuff and im gonna need a few bits to get it thru.
when i got the car it came with a pod filter, fmic and body kit.
naturally the front intrusion bar has been eaten by an angle grinder to make airflow for the fmic, and this obviously isnt going to pass so ill need one of them,
as well as the front bar itself,
airbox,
stock intercooler and some piping,
steering wheel,
can anyone recommend good places to source these bits?? id like to borrow what i can if i can coz this will obviously save me alot of money... any suggestions would be great, even if u reckon i could get away with the fmic or pod would be great news!
thanks.
https://www.sau.com.au/forums/topic/98186-regency-for-compliance-soon/
yeah i already spoke to some guy there and he said it was ok..
EXCEPT - (this is where the fun begins)
ive got a bit of paper here, which was sent to me from RTA talking about it all
GENERAL CONDITIONS:
That on post 1974 vehicles, the engine must remain standard and retain its original induction system.
That the engine MUST retain the original equipment induction system; ie, carburettor, inlet manifold, camshaft, air cleaner, ECU and fuel injection system.
That all emission control equipment and associated plumbing originally fitted must be retained and operational
The fitting of turbo timers, non OEM blow off valves and mechanisms to vary turbocharger boost pressure are not acceptable
so from what i can understand is that to comply the car - you gotta have it like this (plus other conditions that i havent listed but have here on this bit of paper) but if you get defected you can have some of the stuff as aftermarket so long as it doesnt break other rules, like you mentioned it has to be secured etc.
It depends which a$$hole you get at Regency as to whether you pass or not.
Take your dad with you when you go, and see if they go easier on you.
It is pure pot luck, and the rules change depending on whom you ask.
Good luck!
i was thinking about getting my dad to take it in for me..
surely its gotta do something to help my chances..
lets see, 19yo P plater vs 56yo gentleman... lets see what we can do for you sir..
'shes all good mate, just get *something* sorted out as soon as you can'
vs
'you have to change this, this this, this is broken, this is worn, replace this, spend money on that'
    • I downloaded the apps (for windows) and Consult 1 doesn't have this function on it for the Consult 1 plug which I'm pretty sure all Skylines have. You would think someone would have a workaround after 30 years for all Skylines which have ABS.
    • Also, I don't know the actual ABS system on the skylines, but a sneaky thing could be a piece of electronic equipment that makes the ABS think you're moving, and then same piece can send a signal for a locked up tyre... Activate ABS without slamming brakes...
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
