If you look carefully it should have a number 1 printed on the connector. (It will be small writing).
Otherwise measure what wire has +12V with the ignition switched on.
Maybe someone else knows what end?
(I dont have a 3 pin AFM here at the moment sorry)
https://www.sau.com.au/forums/topic/98217-rb25det-afm/#findComment-1784058
thanks man, do u have any experience with wiring in a z32 into a r33 s2 with an apex'i power fc? because the engine light keeps flashing and the fuel pump is going non stop? what the! there is no ignition or fuel maps either after we done a tune last night and it was running fine before the z32?
https://www.sau.com.au/forums/topic/98217-rb25det-afm/#findComment-1784286
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia body...
    • This. A 3d wheel alignment is like $120...just take it to the shop. Since theres probably multiple adjustments that need to be made after changing something. Mine has front/rear lower arms, traction rods, tension rods, camber arms, toe arms, front upper arms, hicas kit, sway bars and coilovers. I measure from the edge of the bolt holes on the originals and set the same length on all the adjustable stuff to dial it as close as I could to OEM. Took it straight for alignment; it didnt feel right at all...after alignment, it feels perfect. Similarly i've just changed the springs on another car; and I still needed multiple adjustments to bring it back in spec.
    • A full Veilside kitted JZA80 Supra in Meriken park in Kobe city a few weeks back
