Hey guys,
As all of you know there is alot of racial tension atm....(unless you live under a rock)
I got these photo's sent to me yesterday.
It apparently happened in Coogee yesterday, round 3ish.
I havnt seen anything about this on the news....coverup?
It must be related to the voilence...
Ive heard things like it was one of the Bra boys cars etc...
Anybody got any details?
https://www.sau.com.au/forums/topic/98276-racial-voilence/
  • Replies 129
I just got the email and it said "about an hour ago" and the time on it was nearly 8am today.
I got this email at 4.23pm yesterday...so it definately happened yesterday.
It looks like it was either around 8am or 3pm seeing as though there is a school kid on the road....
https://www.sau.com.au/forums/topic/98276-racial-voilence/#findComment-1785444
Just got this in an email
You have all probably heard about the riots etc in Cronulla, We have
just
been warned as an Insurance Company for Motor Vehicles that the Ethnic
community are ready to retaliate and hit back at the Australian Race in
the
Parramatta Area. Today there were fights and attacks at Merrylands and
Granville.
Just all be careful and don't go anywhere by yourselves in that area.
They
are jumping out in front of cars to see what race you are then they
start
to hit the vehicle, even while you are inside. Do not stop for anybody
and
make sure your doors are locked especially at traffic lights.
All Insurance Companies do not cover acts of Terrorism and Racial Acts
resulting in Riots. So take extra care. They do however cover radom
acts
of violence by an unknown but you have to cover the excess.
https://www.sau.com.au/forums/topic/98276-racial-voilence/#findComment-1786092
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
    • Could be correct. Meter might be that far out. Compare against a known 5 ohm 1% resistor.
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap.  (edit: I went out and did it right now, the line I had chosen did appear to have no vacuum on it, it used to go to the front of the intake, I've now completely blocked that one off at the bracket that holds several vacuum lines by the firewall.  I T'd into the vacuum line that goes from that bracket to the vacuum pump at the front of the car, but no change in the MAP readings).  Using the new vacuum line that has obvious vacuum on the hose, im still only getting readings between -6.0 and -5.2.  I'm wondering why the ECU was detecting -5.3 when nothing was connected to the MAP nipple and ECU MAP selected as the source. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
