  • Replies 190
Posted Images
i guess i'll just have to wait and see what other nice surprises the guys at the wharf have left for me.
im told that my car may be ready for shipping to sydney as early as friday (10/03/06) :)
im told that my car may be ready for shipping to sydney as early as friday (10/03/06) >_<
That's awesome, assuming it proves true!
well i reckon the worst case scenario puts me at having it in my hands by fri 17/03/06.
...I cant wait... if i get it on the 17th it will be four months since i won the car at auction... damn christmas/new years break!
i get mine on wednesday hopefully! Delivered to my house (melb) from brisbane.
Any idea what is a normal time frame from auction to delivery?
It rests so much on luck, I am sure people can tell you how long they waited, anywhere from 8 weeks to 5 - 6 months if things go slightly wrong...
Really depends on a lot of unrelated variables falling into place and a lot of different people doing their jobs along the way... From when you buy, when paper work is organised in Japan, when the next ship sales (and your car can actually get on that ship, see previous point), how lucky you are getting through customs, how busy the compliance shop is... Most of it is out of your hands so it's all luck and using the right people along the way as far as timing goes.
Example: I purchased my Stagea on the 26th of Jan this year and it is still sitting on the docks in JP, it should be on a boat on the 18th of March, whoohoo! that's only 2 weeks away!!!
Cheers
Luke
Cheers
Luke
Hopefully my 2 Stagea's will be on the same boat aswell
The wait sucks!
I AM SHE finished working on my car today. so just have to wait until the compliance plate gets back from canberra and its ready to go.
...although i still have to wait to get my front bar fixed (apparently it has six cracks in it) which is costing me $550 plus getting it painted on top of that :(
...some pics of the front bar
post-25286-1141715102.jpgpost-25286-1141715127.jpgpost-25286-1141715151.jpgpost-25286-1141715178.jpgpost-25286-1141715293.jpgpost-11016-1125141835.jpg
Bugger. Can this sort of thing be covered by insurance?
If it was on a Kiwi Car Carriers ship then it "should" be covered. If it wasn't like that when they loaded it and it was damaged either loading or unloading then it "should" be covered under their policy, I was having a read through their site yesterday after the damage was mentioned. There is an Excess attached which is not quoted so that could be more than the cost of the repair, worth looking into of course.
Luke
yeah hopefully i can get reimbursed, i gave SEAWAY a call (they organise a bit of the transport stuff) and sent one of the ladies there an email with photos of before and after the front bar was smashed. i'll find out tomorrow what is happening when i get a call from SEAWAY
no still dont have it yet, apparently i might have it early next week.
from what ive heard, TOLL have had some sort of strike thingy and they havnt been picking up any cars for the last two days...just my luck eh
from what ive heard, you cant have anything in the car when it is getting transported...is this true?
Yeah nothing in the car at all, for safety and insurance reasons I think.
That is generally when shipping form Japan
You just can not trust the doggy shipping companies
You should be fine in Aus, just make sure it is listed on the transport documents as contents in vehicle
Just check with TOLL or TNT
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
