Purchased a pair of R34 eyelids from MFX about a month and a half ago; finally got them painted and fitted today :D Decided to go DIY as the initial cost of the item didn't warrant a professional spray job. Besides, the item is so damn small it's going to be near impossible to funk it up~
Ingredients:
2 x MFX R34 Eyelids
1 x Can of Automotive Spray Paint (Nismo White)
1 x Can of Laquer
1 x Brick (to hold eyelids up above ground)
1 x Old Newspaper (to keep my driveway spotless)
Process took 2 days as I only began work Saturday evening. Applied 2 initial coats of white and left to dry overnight. Came back from a small meet-up today and finished it off by applying a final coat of paint followed by 2 coats of laquer.
Voila....
Eyelids fitted using double sided adhesive tape; had to be cut to size. Because these eyelids "flex" to a certain degree, fitment was clean and easy as you could bend them to the shape of the headlight :)
Photograph'os:
post-19974-1134893925.jpgpost-19974-1134893956.jpgpost-19974-1134893980.jpgpost-19974-1134894005.jpgpost-19974-1134894031.jpgpost-19974-1134894090.jpgpost-19974-1134894118.jpg[attachmen
=15363:attachment]
Still not sure whether I'll keep em on for good... a little undecided atm! Maybe they'll grow on me so they'll stay on for a month or two :) Good thing is that the adhesive is only on the plastic housing of the headlight which means removal is a piece of cake!
https://www.sau.com.au/forums/topic/98855-installed-r34-eyelids/
I think you are 100% correct.... the East Bear ones look much more aggressive! But could that be because of the front bar it is partnered with? Could be a "package" feel rather than the single piece feel...
Anyways, thanks for the feedback guys :)
IMO, look's more aggressive yes.. but still needs more covering the light on the other hand - if you got the r34 GTR style grill it looks a whole lot better! I recon even without the lids.. just looks badass
Edited by ignuz
ignuz; I agree that the GTR grille would look awesome no doubt, but the amount of work + money to get that look is not justified in my books. There are just too many parts that need to be replace in order to achieve that look - and only so that the eyelids look more agressive, proves my point even more :D
oh :D Pictures don't mean anything anyway... always looks different in person :D
oh and also.. i can't tell if you've already done it or if it even can be done.. but if you take the lids off and just tint the glass a bit.. make it darker i think that would look alot more aggressive even without the lids.. that white on black look :D
Edited by ignuz
  • 4 weeks later...
  • 1 month later...
stan... those eye lids are alrite... the "Angry" C-West ones are ghey... I got a set and had em on the car for 3 days and couldnt hack it. Stock is the best... R34 headlights give the R34 that uniqe beefy look so why cover them up??
  • 1 month later...
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
