What is the factory size of the speakers in the front and back.
what direct replacements can I get.
if no direct replacement, can I get some speakers to replace them without too much mods to doors and parcel tray?
thanks
I cant remember what size the originals were, but it wasn't hard at all to get new ones in there. The hole in the door is big enough to get just about any speaker in there.
My 32 had a plastic mount that screwed onto to metal part of the door to hold the factory speakers in. All I did was unscrewed that off, and made up my own mount / surround for my 6 /12" Alpines out of like 3mm wood (dont know what type... just soft crap) and they hold in there perfectly.
Door trims go back overtop with the factory speaker grills... Wouldn't even know they were there...
My rear speakers are 6" coax's and they fit in there perfectly but the screw holes didnt match up, so I used a soft glue like hot glue to stop rattling and could only screw it in with 2 screws.
- Dave.
Edited by Crimpage
I'm not that well informed with speakers.
what do I want for the front and back.
2 way?
3 way?
which ones go where?
I just want something better than factory so I might even just buy cheapo sony speakers.
don't want a sub.
I need an amp I guess so for these 4 speakers, do I want a simple 4 channel amp?
The deck I am looking at states 208watts.
4 x 50 or something.
do I need an amp with that?
I'm not a big loud stereo fan.
just want to be able to hear music over exhaust and open windows without buzzing or distorsion.
Cheaper the better so what do you all recommend?
Double check the holes in the front as I can't remember whether they are 5 x 7 or 6 x 4. Either way JBL make small oval speakers - see below
http://www.strathfield.com.au/ViewProduct.asp?ProdID=997
http://www.strathfield.com.au/ViewProduct.asp?ProdID=998
The 5 x 7 set are supposedly pretty good for the price.
Any reasonably priced 3way 6.5in speaker should fit the bill for the rear. Just have a listen in the shop.
The 208w deck is enough if you don't require thumping levels of sound. Just make sure the factory Skyline front & rear amps are by passed as they suck terribly. Just run new speaker cable from the deck straight to the speakers.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
