Hey could someone do me a huge favor, i need someone with an r33 to remove there arial and tell me what colour wires go where on the plug. You will need to open the boot and remove the left hand garnish and then remove the 2 bolts holding the arial in, then you will need a pair of pionty nose pliers to remove the locking nut from the top of the arial (where it comes out from), then the whole arial unit will be able to be pulled out. I have a picture attached with a drawing of the back of the plug with numbers on it, if someone could tell me what colour wires they have going to each number it would be a great help..
Edited by Mick
https://www.sau.com.au/forums/topic/98878-arial-plug/
I note that you have posted looking for a replacement aerial.
I would not mind looking around in the "wheel well" but would baulk at taking the aerial out.
Is it totally necessary to remove it from the body ?
Do you still want someone to try and identify the pinouts ?
El Bee
https://www.sau.com.au/forums/topic/98878-arial-plug/#findComment-1810574
Yes i still would like to know what colour wires go where in the plug.
The arial unit needs to be removed to get to the plug, its very very simple to remove, anyone could do it even if they arnt very mechanicaly minded ..
Behind the left trim in the boot is 2 10mm bolts that need to be removed and the locking nut at the tip of the arial and the whole unit will come out without any trouble, it will also go back in just as easy ..
I hope you can check your plug for me, either way if you want a copy of the nissan fast cds i will be happy to send you a copy wether you check it or not. Im all for sharing ...
https://www.sau.com.au/forums/topic/98878-arial-plug/#findComment-1811186
I just tried to get my arial out to get a copy of the plug for you... its not as easy as you think.
I gave up as i ended up putting a dent in my rear 1/4 panel... which plug are you after exactly? cause none of mine looked to have any plugs attached.. it was more a direct connection to the arial. I dont use mine anyway, just burn a mp3 cd or something. fcuk the radio.
Dayne
https://www.sau.com.au/forums/topic/98878-arial-plug/#findComment-1812517
    • Or just put in a 1JZ, and sell me the NEO head 😎
    • Oh, it's been done. You just run a wire out there and back. But they have been known to do coolant temp sensors, MAP sensors, etc. They're not silly (at Regency Park) and know what's what with all the different cars.
    • Please ignore I found the right way of installing it thanks
    • There are advantages, and disadvantages to remapping the factory.   The factory runs billions of different maps, to account for sooooo many variables, especially when you bring in things like constantly variable cams etc. By remapping all those maps appropriately, you can get the car to drive so damn nicely, and very much so like it does from the factory. This means it can utilise a LOT of weird things in the maps, to alter how it drives in situations like cruise on a freeway, and how that will get your fuel economy right down.   I haven't seen an aftermarket ECU that truly has THAT MANY adjustable parameters. EG, the VAG ECUs are somewhere around 2,000 different tables for it to work out what to do at any one point in time. So for a vehicle being daily driven etc, I see this as a great advantage, but it does mean spending a bit more time, and with a tuner who really knows that ECU.   On the flip side, an aftermarket ECU, in something like a weekender, or a proper race car, torque based tuning IMO doesn't make that much sense. In those scenarios you're not out there hunting down stuff like "the best way to minimise fuel usage at minor power so that we can go from 8L/100km to 7.3L/100km. You're more worried about it being ready to make as much freaking power as possible when you step back on the loud pedal as you come out of turn 2, not waiting the extra 100ms for all the cams to adjust etc. So in this scenario, realistically you tune the motor to make power, based on the load. People will then play with things like throttle response, and drive by wire mapping to get it more "driveable".   Funnily enough, I was watching something Finnegans Garage, and he has a huge blown Hemi in a 9 second 1955 Chev that is road registered. To make it more driveable on the road recently, they started testing blocking up the intake with kids footballs, to effectively reduce air flow when they're on the road, and make the throttle less touchy and more driveable. Plus some other weird shit the yankee aftermarket ECUs do. Made me think of Kinks R34...
    • I do this, I also don't get the joke
