I don't believe they will destroy the coil packs, but if you have standard coils irridium plugs will make them work harder. For the best performance with these plugs you probably need a set of split-fire coils and have your plugs gapped correctly. i.e. high boost smaller gap around 0.8 to 0.9mm. Standard boost then the 1.1 gap will work ok.
I changed to NGK irridiums about 4 months ago and had nothing but trouble, misfiring, hesitation in the mid rev range. The smaller gap solved the misfiring but the car just never reved the way it used to. This is because my standard coil packs couldn't handle the irridium plugs.
I recently changed my irridiums to NGK copper ®, gapped them at 0.9mm and the car runs like a dream. They will only last about 20-30k depending on how you drive, but for $20.00 for a set of 6 who's complaining.
If you feel that you need the better plug, best to stick with NGK platium. The only problem is they come pre-gapped so you need to order them with your preferred gap.
Paul.
umm, okay. So, should I be overly concerned about this? Does damage usually occur within weeks, or do I have a few months?
Its not really damage that occurs, it's just that they don't work as well. Especially if the coil packs are getting older this doesn't help. Eventually of course a coil pack will die. If you stick with irridums then use splitfire coils, around $800.00.
Paul.
in a good way thats good to know..when I bought my skyline almost 3 months ago, my mate made me buy the iridium plugs. Spend a fortune, then figured it was too much hassle to change them, on account of the ornament and piping covering up the plugs and coils..so they've just been sitting there in my garage for the last 3 months...
Hey can someone please explain why you guys are making the spark smaller??? I dont understand, really it doesnt make sence, well not for me anyway.
I thought the bigger the spark the better the bang?
also matty_tonkin Super cheap sell them, $20 for a set of 6
Edited by 7yphon
The deal with closing the gap is that with running higher boost the forced air can blow the spark out.
Which causes the car to go and sound like a heap of crap when it hits full boost.
I bought Iridium 0.8's for my car when it came over because even though running factory boost levels it wouldn't handle it when it hit around 5000rpm.
And plugs that were in it were Iridium 1.1's
but ive heard that compared to japan our premium fuel quality would be there everyday cheap stuff.
Thats what i know anyway, hope it helps. :)
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
