well... this mite be a stupid question. but il ask anywayz
last nite i was dragging mmy mates wrx
out back of werribee we got a few 1/4 miles marked out
me being stock and all and his wrx having full 3 inch exhuast from turbo and boosted up..
off course i thought he was gonna kick my arse but i never back down from a drag race..
so anyways on take of he kicked my arse im talking 2-3 car lenthgs
i was wheel spining way to much where he just took of.. damn AWD
but still as we went on i started catchin him.. at the end of the 1/4 mile i was practically dead even with him..
but the question is......
WHATS DA BEST WAY OF GETTING TRACTION?? is it the plane and simple answer of geting some 255 wheels at da back.. or is there any other tricks of da trade>????
i tried taking of in 2nd gear like what we do in my mates VL but the skylines seem to buckle down and dont like it much..
hmm
any help would be great
thanks
ps..
Inark is gay..
https://www.sau.com.au/forums/topic/9897-traction/
Traction is not about RWKW, in fact the more kw the more harder to get the traction issue right. IF in 1st gear, doen't rev it past 4k max, it all about ballancing the power delivery. Maybe try to use your hand brake to launch, this way your engine is loaded (thus starting to spool the turbo, and yes you may be riding the clutch a little. This is just my opinion i would also like to read others.
https://www.sau.com.au/forums/topic/9897-traction/#findComment-153639
If you've got the $$$ get some good tyres on the back, it'll make a big difference.
I'm not talking 255 rubber, just a really good tyre. I got a set of 901's on the back and they are so much better than what I had.
Pineapples are apparently a good thing too (they are on my 'to do' list). Reduces axel tramp and gives better grip.
Funny that your GTS-t is stock, and after the 1/4 mile it's even with a silghtly modded WRX - I love it :D
https://www.sau.com.au/forums/topic/9897-traction/#findComment-153675
You gotta learn not floor it during take off and hold the enthusiasm a bit at bay. Flooring it off the line isn't the best in a RWD. Wait until you're moving a bit then fully give it the boot.
Handbrake starts for me just result in more wheelspin...
https://www.sau.com.au/forums/topic/9897-traction/#findComment-153731
Deffinetly get some "PINEAPPLES". These things will cost you $120 delivered from Meggala and Dr_Drift yet they are worth soooo much more.
Considerably removed my axle tramp and my car is 500% better off the lights and around short fast corners the rear end sticks.
You can read my small review
HERE
https://www.sau.com.au/forums/topic/9897-traction/#findComment-153749
I _should_ be getting my car back tonight with the pineapples. I'll post how it goes post-pineapple. Soon everybody will have 'em :)Mine generally bounces around like a m/****er and goes nowhere on high boost if i don't do it properly.
https://www.sau.com.au/forums/topic/9897-traction/#findComment-154133
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
    • Hey all. I’m looking on replacing my speed sensor on my R33 GTR. Will the center differential need to be drained, and if so, the center diff uses ATF fluid D? I found information on the transmission, front diff and rear diff. Can’t find a for sure answer for the center diff. Any help will be greatly appreciated.
