Hey people,
Ive got an 93 r33, and im having some issues with my automatic. ive just had the auto rebuilt but it didnt solve it.
basically... when it feels like it, (its not to often and has mostly occured when its hot) it will get stuck in first gear. it weird... when it does i accelerate and instead of launching forward it just revs and maintains a constant speed (which indicates to me it cant be slipping into nuetral as it doesnt roll to a stop).
i was just wondering if anyone has encountered anything like it.
I can also picture alot of people saying "you should of got a manual" and dont worry, at the moment given the choice i would have. so to all those people... any idea on how much it would be to convert it?
cheers to all that have any idea... coz im going insane.
https://www.sau.com.au/forums/topic/99003-auto-issues/
ive got the same problem on my car (93 r33 also)
im pretty sure its something electrical because when that happens i quickly push the SNOW button and it goes into 2nd and works fine.
maybe start from there, check all the electrics on it.
Edited by SECUR1TY
https://www.sau.com.au/forums/topic/99003-auto-issues/#findComment-1803044
hey guys i have the auto box manual and fault codes here
http://www.skylinesaustralia.com/forums/in...showtopic=88772
hope that helps my R32 also has this problem as all the autos are the same model i am trying to diagnose their problems and note it down for every one to use.
the problem sounds like the band adjustment it's only set at 4nm-6nm i will let you guys know when i find an easy way to get to the adjusting bolts
https://www.sau.com.au/forums/topic/99003-auto-issues/#findComment-1808646
i have the same problem but only very rarely.
I have driven around with the carmen scan on and its seems to come up with the speed sensor (automatic rotational sensor) i think thats wat its called. Its the sensor on the rear left side of the gearbox (siting in the drivers seat) I am pritty sure this is the problem however i have not forked out for a new one yet and will probaly not be doing so as i'd rather go manual i think. )its 240 new from nissan
https://www.sau.com.au/forums/topic/99003-auto-issues/#findComment-1813123
nah its not the torque converter i don't think as its happens to infrequently and i get the power light flashing on the dash. Reseting computer does nothing. All you can do when it happens is come to a complete stop which sometimes works or turn car off then on and that always works
https://www.sau.com.au/forums/topic/99003-auto-issues/#findComment-1813549
i gather the SNOW & HOLD buttons in 32's & 33's do the same thing like the power buttons,,so SECUR1TY...are you saying to have the car in drive when taking off and use the snow button to shift into 2nd?
at what revs are you shifting to 2nd?
Edited by RSTME
https://www.sau.com.au/forums/topic/99003-auto-issues/#findComment-1816466
im not sure if they do the same thing mate. ive got a snow button, power button and an a/t button.
when my gear gets stuck i just push the snow button and it goes into 2nd no matter what rev im at.
if im at the lights and ive got the snow button on it'll start in 2nd.
https://www.sau.com.au/forums/topic/99003-auto-issues/#findComment-1816506
thats correct RSTME it will hold the gears back from reving
secur1ty when you are doing 100kmh push the snow button it wont do anything it certinaly wont drop into second how ever at the lights when you push the snow button it will be in second gear so you dont spinn the wheels in all this aussie snow.
what i was trying to say is when your car gets stuck in gears as you are driving it has changed in to power mode automacticaly. to relece the gears you have to tap the power button on and off
https://www.sau.com.au/forums/topic/99003-auto-issues/#findComment-1816802
yep,i tried using the hold button to shift to 2nd just then and its not good.
id like to go in another auto skyline to make sure i dont have a dodgey g/box.
anyone happy with their auto box and willing to take me for a spin?
https://www.sau.com.au/forums/topic/99003-auto-issues/#findComment-1816823
i know it wont shift it into second, thats now what i was saying. the problem is the car getting stuck in first, so what i do is push the snow button and it shifts into 2nd.
and it doesn't get stuck in power mode as even in power mode it will change gears but only a little higher than normal or untill you back off a little with the accelerator. when the gears get stuck it will stay in the gear untill you either rev it out till around 5000, or in my case push the power button.
https://www.sau.com.au/forums/topic/99003-auto-issues/#findComment-1816884
oh that is more of a stall converter/band problem secur1ty its not the same as the R32 problems being stuck in every gear as you accelerate
the gear box type/part number may be the same but have clearly diffrent problems
just to clear things up i own an R32 and R33 both auto's so i understand your frusteration
rstme how long has it been since your auto was serviced if you want i can talk you through a service the cheap way its quite easy
https://www.sau.com.au/forums/topic/99003-auto-issues/#findComment-1816922
ok the first few things you will need are 4 liters of castrol TQ dexron 3 this is a heavy load oil an oil catch tray 4 litre one
scocket's 10mm for the pan bolts and filter bolts and 19mm for the drain plug.
A hand pump just a simple squeeze one i used an outboard fuel line not recomended for this though lol.
A gasket from an auto service centre part no.RE4R01A ask for the gasket part number alone because if you ask for a skyline one they will charge you like $20+ i got mine for $8 its a cork one they are the best no gasket glue needed.
Some spare fuel to clean the filter dont buy a new one all they do at the service centers is clean it's the same with nissan.
let me know when you have all that stuff and i will give you the next steps with pics
Edited by xr8eater
https://www.sau.com.au/forums/topic/99003-auto-issues/#findComment-1817078
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
