I had a HKS super sequential on while ago but sold it as a BOV on the auto doesn't work as well. In first gear sometimes it would stall after accelerating and stoping at low speed. As for the noise it doesn't do it on gear changes like a manual, but you could still get it to do it.
I think BOV are for manuals only. But hey give it a go its fun.
https://www.sau.com.au/forums/topic/99092-bov/#findComment-1804778
WOW, for $700 a BOV id rather not have a BOV and just rebuild the compressor wheel every time (debatable) the compresser surge kills it
what the hell does a $700 bov do, provide sexual favours, honestly..
well to answer your question, this $700 BOV allows you to control the amount of sound it gives off with the twist of a knob from inside the car, you can have it on full volume then turn it so that there is no sound at all, which is a great idea for when you are having to deal with the police and their defects
https://www.sau.com.au/forums/topic/99092-bov/#findComment-1805073
Yeah i'll get some pics tonight for you. i haven't sealed it 100% around the bottom of the AFM, but i have insulated the box, as it's just aluminium. air flows up from under the car behind the passenger side headlight and into the pod.
https://www.sau.com.au/forums/topic/99092-bov/#findComment-1806301
I have a GFB Stealth, came with the car when I bought it, very nice to be able to twist it and make it louder or softer, but have to open the bonnet still to do it, but still, with my tune I dont have any problems with stalling or anything, but the stealth is a dual atmo/plumb back.
It's set to about half way atm, but my god it shakes all the windows within a 5km radius when it is set to full atmo :D
https://www.sau.com.au/forums/topic/99092-bov/#findComment-1806758
yeah i got a gfb stealth on mine and it works well but 700 for the in cabin adjustable is a bit too much i rekon. i will contact my supplier get you a price on it and see how it compares. but i think i can get you one cheaper than that if u do really want it
https://www.sau.com.au/forums/topic/99092-bov/#findComment-1807600
i do want one, however it will be a few months before i get my stagea, and i wont be doing any spending until i have the stagea on the road, i dont want to spend to much money and end up not having enough to get the car registered.
https://www.sau.com.au/forums/topic/99092-bov/#findComment-1808365
from someone on the forums doing a group buy of R33 and R34 air boxes. i got one for and R33 and R34 to see which would fit better, but they're about the same. i gave the R33 one away to a mate though.
i don't know if the group buy is still up, it was a while ago
https://www.sau.com.au/forums/topic/99092-bov/#findComment-1811777
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
