I had a HKS super sequential on while ago but sold it as a BOV on the auto doesn't work as well. In first gear sometimes it would stall after accelerating and stoping at low speed. As for the noise it doesn't do it on gear changes like a manual, but you could still get it to do it.
I think BOV are for manuals only. But hey give it a go its fun.
https://www.sau.com.au/forums/topic/99092-bov/#findComment-1804778
WOW, for $700 a BOV id rather not have a BOV and just rebuild the compressor wheel every time (debatable) the compresser surge kills it
what the hell does a $700 bov do, provide sexual favours, honestly..
well to answer your question, this $700 BOV allows you to control the amount of sound it gives off with the twist of a knob from inside the car, you can have it on full volume then turn it so that there is no sound at all, which is a great idea for when you are having to deal with the police and their defects
https://www.sau.com.au/forums/topic/99092-bov/#findComment-1805073
Yeah i'll get some pics tonight for you. i haven't sealed it 100% around the bottom of the AFM, but i have insulated the box, as it's just aluminium. air flows up from under the car behind the passenger side headlight and into the pod.
https://www.sau.com.au/forums/topic/99092-bov/#findComment-1806301
I have a GFB Stealth, came with the car when I bought it, very nice to be able to twist it and make it louder or softer, but have to open the bonnet still to do it, but still, with my tune I dont have any problems with stalling or anything, but the stealth is a dual atmo/plumb back.
It's set to about half way atm, but my god it shakes all the windows within a 5km radius when it is set to full atmo :D
https://www.sau.com.au/forums/topic/99092-bov/#findComment-1806758
yeah i got a gfb stealth on mine and it works well but 700 for the in cabin adjustable is a bit too much i rekon. i will contact my supplier get you a price on it and see how it compares. but i think i can get you one cheaper than that if u do really want it
https://www.sau.com.au/forums/topic/99092-bov/#findComment-1807600
i do want one, however it will be a few months before i get my stagea, and i wont be doing any spending until i have the stagea on the road, i dont want to spend to much money and end up not having enough to get the car registered.
https://www.sau.com.au/forums/topic/99092-bov/#findComment-1808365
from someone on the forums doing a group buy of R33 and R34 air boxes. i got one for and R33 and R34 to see which would fit better, but they're about the same. i gave the R33 one away to a mate though.
i don't know if the group buy is still up, it was a while ago
https://www.sau.com.au/forums/topic/99092-bov/#findComment-1811777
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
