what ever man the 1jz are awsome engines! they can handel 500kw and the 2jz can handel up 2 800kw on stock internals. 1 of my mates has a big T78 set up on his supra makeing huge power! i say go for it! not many conversions like that around id love to see how u go about installing!
https://www.sau.com.au/forums/topic/99218-1jz-into-ceff/#findComment-1807371
mr Eps, I assume you don't live in melbourne, where you have your car inspected only once and never again for as long as its in your name, unless the police ask you to.
Its a common swap, and done because those engines are readily availble in those countries, unlike the RB (the closest they get to an RB is the RB20E which is an SOHC 2.0L N/A and the RB24S which is an inline 6 carby engine). With this in mind, its easier to do an RB25 or RB26DETT swap in a cef, however the 1JZ and 2JZ swaps are doable.
You'd best be asking on a thai ceffy forum like http://www.cefiro-thailand.com
or
http://rcweb.net/forums/forumdisplay.php?f=31
https://www.sau.com.au/forums/topic/99218-1jz-into-ceff/#findComment-1807624
Thankyou :rofl:
The car would be engineerable (is that a word ?) wouldnt it ? I assumed it would be the same as putting an RB25 in.
or
https://www.sau.com.au/forums/topic/99218-1jz-into-ceff/#findComment-1808398
well im from perth and to the best of my knowledge (correct me if i'm wrong please) but i think it's un-engineerable (is THAT a word?) to have trans build engines in
like you can't put a lada niva motor into a mitsubishi lancer,
nor can you put an engine in that is older than the car's build date
ie: V35 skyline can't have an RB transplant etc,
https://www.sau.com.au/forums/topic/99218-1jz-into-ceff/#findComment-1809283
over here you can put any engine into another as long as it meets ADRs, then an engineer will have to sign off on it to certify that the swap is legal. Usually costs about $500 - $800 to get done. Once that's done then the car is legal with that engine.
The other way that most people do it is rego the car with the engine its supposed to have in it, then do the swap. Engine swaps aren't a roadworthy issue, so the roadworthy shops won't care. It is illegal, but it happens a lot in VIC. The only time you can get caught out is if you have a cop go through your car, or you go to resell it and it needs to go through the registration process again.
https://www.sau.com.au/forums/topic/99218-1jz-into-ceff/#findComment-1809759
Yeh that was my understanding too. That you just have get an eng cert.
https://www.sau.com.au/forums/topic/99218-1jz-into-ceff/#findComment-1810505
Removing the Toyota markings from the surface, whos to know its a Toyota motor at the pits? I think is definately doable....
https://www.sau.com.au/forums/topic/99218-1jz-into-ceff/#findComment-1810525
if you guys remember that Ferrari Enzo kitted 180sx that was on the J-Spec mailing list, it was bought by a guy in Syd who was gonna put a worked 2jz (out of his old silvia) in it.
https://www.sau.com.au/forums/topic/99218-1jz-into-ceff/#findComment-1812924
    • I believe @Duncan has given it a crack at Mt Buller before (in actual race conditions)
    • All my Polish car culture insight comes from watching Nightride. So I half expect this to get 1UZ swapped eventually?! Are you going to drive it in winter? I'm always curious how ATTESA would hold up in the snow. There isn't that much opportunity to try it in Australia.
    • My steering lock unit on my Infiniti G37 has failed. The car is a local 2012 Infiniti G37 (Q60 ) I need to replace the unit My local mechanic said i need to buy a complete steering wheel assembly. Does anybody no any mechanics in Gold Coast or Brisbane who can fix this issue or where i can buy just the Steering lock control unit. Thanks
    • thanks, will conduct myself accordingly. i unfortunately put about 150 miles on the car before reading this thread again, however no PS issues, and definitely no turbo issues. it spools normally and still feels fast to me, probably because my previous car was an N/A auto sedan...gonna go fix the PS vacuum line though lol. safe to say, got what i came to this thread for. thanks
    • Agreed, I've never seen a 260RS specific manual. As GTSBoy said it will mostly be stagea other than the engine loom https://www.hgeconsulting.com.au/stageaservicemanual.pdf
