Im looking to start a group buy for genuine RB25DET Idler Assembly replacement bearings.
After recently doing my own 100k service I was quoted $350 for the timing belt idler bearing and another $130 for the timing tensioner pulley bearing from Nissan.
I was also quoted $225 for the timing belt idler bearing and $95 for the tensioner pulley bearing from Just Jap.
I have managed to get hold of a supplier who is happy to do a group for $240 delivered on both the Idler and Tensioner bearings (Genuine Nissan Replacement parts)
Both of these a requirement when doing the 100k service when changing the timing belt, and is also a good idea when rebuilding your motor for peace of mind.
Looking for around 10 buyers to achieve this price.
Closing Date: 20/1/05
PM me for any further questions or details.
https://www.sau.com.au/forums/topic/99329-rb25det-100k-service-bearings/
from memory i think you can get nsk bearings for about the same price or cheaper.
Tensioner NSK 60TB0683 EA7L 806
Idler NSK 56TB2801B01 ENSL 309
not geniune but still does the same job. anybody have any idea if the nsk's perform better?? i might be interested.
Yes they do come with the sleeve etc.
I started a thread in the maintenance section yonks ago when I did the idler/tensioner over a year ago.
The thread was titled fiddly stuff and if you do a search you will find the right part numbers in the thread.
They are cheaper than the genuine ones and I can't see any reason why they wouldn't last as long.
One guy got them cheaper than I could but he was in sydney.
From memory it was about 60 for the idler and 105 for the tensioner.
I've used NSK in all my vehicles and never had any troubles - they are good bearings.
Cheers
  • 5 months later...
yeah the nsk number for the idler is fine if you really wanna press them out bud ull damage the bearings doing this...hint vl rb30 tensioners FIT!!!!!
So these are the complete tensioner and idler assemblies to suit an RB25DET?
Found out today, CBC do a timing belt kit for RB25DET's, includes timing belt, tensioner and idler pulleys, cam shaft and crankshaft seals, for about $350.
thats not a bad deal. what kind of bearings do they supply in the kit?? genuine?
I'm pretty sure they are NSK bearings, which would be as good as genuine.
I wouldn't be surprised if the genuine ones are NSK.
I talked to Bearing Traders in Mayfield Newcastle, and they can get the bearings at a rediculously cheap price, i couldn't believe it.
Tensioner NSK 60TB0683 EA7L 806 $29.63
Idler NSK 56TB2801B01 ENSL 309 $49.76
Nice work :P I got a 100k service coming up and live in newcastle so this should help save me some money.
I only got my car a couple of months ago (98000km), and when I got it I knew it needed the timing belt done... but I didn't know anything about bearings.
I had it done at Caringbah Automotive Repairs & Service in Taren Point. The invoice I got says "T1040 Timing belt" but nothing about bearings. So after reading this thread I'm thinking it should have been done, and if so is the mechanic to blame for not knowing to do it?
I've just done over 100000km so I guess I should get it sorted. Wonder what other surprises are waiting to empty my wallet... :P
It depends who you talk too, I've heard SK say that it is not required to change the pulleys when you change the timing belt, but i'm quite sure it is recommended to be done with the 100000k service.
    • I've replaced the front brakes of my NA to 324 brembos and 350z calipers: i'm going for 225/40-18 up front and 245/35-18 in the back. I have Rays 7.5*19 ET35(225/35) in the front with 5mm spacers otherwise the calipers "lock up/ won't rotate". When i use the calculator i come up with 8*18 ET30 for 225/40...... but not sure i get problems with the calipers. Anyone riding around with 18 inch. that can confirm "that it'll fit"? In the back it's 7.5*9 ET30 (245/30) with the 5mm spacers, but there is no problem with the standard small brakes, so i want to take 8.5*18 ET25 (245/35).
    • Lol.. but then.. always come back to a JDM..
    • Glad to hear. If possible, get your tuner to check air's to make sure everything is still where it should be.
    • The problem with FB/Insta/Reddit etc comments relating to cars is simple. You get to ask a question once, and get one round of replies. For things that can actually be answered in a few lines of text, once, it's fine. After 6 hours, your original question is lost to the void. There are no follow ups, additional questions, anything. No project car is ever such a simple list of questions to ask. You need discussion.
    • Welcome.  Here's what I have noticed about forum vs FB..... FB; seems to be wallet racing, and the same few questions asked over and over. There *may* be some groups that are closer knit, but most have changed for the worse. SAU; unfortunately, no longer in its glory days. But....genuine people with similar interests. Not all about how much you spent and saying you dont have enough power. Sooooooo much knowledge available. Have personally seen people post up about literally topics I made myself, asking on FB like no one has done it before. Most has been done, and most of that is here.   If you ever feel like just general chatting theres the wasteland.  Other interests are also generally covered in other areas of the forum. Hope you enjoy hanging around. We would love to have you.   P.s. nice 32 😀
