R32 Gtst:
Engine: Rb25det conversion (rebuilt, forgies), Flowed head/port polish, HKS 275 camshafts, HKS head gasket, Trust Td06-25g turbo, Trust top mount manifold, Trust 50mm waste-gate, Trust front mount intercooler, Trust Oil cooler and relocation filter kit, GReddy Type-R BOV plumbed backed, 850cc injectors, 3inch dump pipe, 3inch dump pipe back exhaust, custom cold air intake box in standard intercooler position, HKS filter, earth wire kit, huge radiator. HKS F-con V.
Suspension And Running Gear: Rebuilt Rb25det gearbox, brand new twin plate OS clutch, Nismo locker diff, Tein adjustable coilovers, 17inch Nismo rims.
Exterior: Genuine GTR front bar with N1 air slots, Type-M side skirts and rear pods. Blue pearl white respray, Semi clear factory indicators.
Interior: Front and rear GTR seats, Skyline floor mats, custom dash cluster; Auto meter monster tacho, Pivot 350kph digital Speedo, GReddy exhaust temp gauge, GReddy oil temp gauge, GReddy oil presser gauge, Tomei boost gauge, Techtom display unit with shift light, short shifter with Razo gear knob, aircon/heater unit relocated to glove box with HKS F-con, HKS turbo timer and HKS boost controller.
ICE: Jap brand head unit with separate equalizer and aftermarket speakers all round.
490rwhp @ 1.5bar and advanced the timing. Plenty more horse power left to be had if you ditch the F-con, or chase up a retune.
The car has been built as a weekend slider, and street warrior. I don't have quarter mile times, nor never will due to lack of traction and interest in setting the car up for times. What the car has been BUILT for and gets USED for reflects its condition! People who want a show car need not ring this isn't the car for you. In saying that, the car is clean and only has minor marks and a few pin dents. The trim and inside is generally clean, the drivers seat has a small rip in it from my belt, dash is mint and has all aircon vents.
Car is owned by a sales executive, and often sees daily duties, no over heating problems. Been through peak hour morning traffic in Brisbane more then once.
I'm asking $23,500ono OR Swap/Trade The car owes a lot more but my loss is some one else's gain. I'm the first Australian owner, and got the car from a broker, genuine reason for sale; lack of interest and would rather the money for invesments and a more suitable car for work.
*Note* Car is gutted, only has two seats, cage, door trims and dash. All trim come's with car, but you put it in.
Price: $23,500ono OR Swap/Trade.
Contact: Josh
Phone: 0407 706 760
Email: [email protected]
Don't PM as I won't check it, all general inquiries on cell # during work hours, unless other wise a very serious buyer.
RWC and Rego negotiated pending price.
https://www.sau.com.au/forums/topic/99337-500hp-ex-track-r32/
Has Matty tuned the car yet? If im correct in your previous post about this car you said you were going to get him to retune it?
Is the quoted figure from his dyno?
thanks
No he hasn't, I work Monday to Sat. I have zero time to play with cars.
Have you got any pick of the inside and cage?  interested but not sure how ill get it though regency with cage
thanks matt
If you're worried about regency then I think the cage will be the least of your worries.
Greg
thanks matt
This car won't get through regency the way it is. You would have to take most of the stuff off I'd guess?
Pm me your email addy and I'll send some pics.
yeah cheers, yeah i know ill have to get in to standard which wont be a problem but if there is any signs that a roll cage was fitted then ill have dramas. email me pics on [email protected]
cheers matt
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
