hey guys i just bought a std r32 gtst (only pod n 3 inch exhaust) n a mechanic said its been boosted well above 7psi n i dont have a boost controler to turn it down, even on low trottle the boost runs very quick to show reading over past the factory boost guage of 7psi, if im runnin this high boost for long,
a) what damage could it be doin to my engine n turbo since i dont have a front mount or any other mods for sufficient airflow cooling for the boost level (prob 10/11 psi)? if so what would be a safe boost level without puttin a strain on the engine without the frontmount?
B) what would be the cheapest n best way to fix the problem? (maybe turn the boost back down with a manual boost controller)
c) would a bleed valve help?
d) i also get 300km on a 42l tank with only some racing, is this decent?
thanks guys for any help you can give me.
https://www.sau.com.au/forums/topic/99407-plz-help-too-much-boost/
If its showing 7 on the factory guage, it means its running over 14psi as the factory guage uses different units to psi.
The only way it can run more then standard boost is if the wastegate actuator has been changed, its stuck partially closed, or it has a bleed hole or split in the hose between wastegate actuator and the turbo compressor cover.
Check that first.
11-13psi is FACTORY :lol:
No its not
Factory is about 7psi, with a full 3inch exhaust and pod it will creep to 10-13 though, I know mine did.
Theres no way to turn it back down without getting a different spring. A boost controller will only allow you to set it higher then what you currently have. Id just take it easy on the hot days and get a FMIC so it doesnt cook the air. If its really going up to 14psi Id get the spring/actuator checked as somethings wrong there and it'll kill the turbo pretty quick smart and really cook the air.
does it still run good?
if so get a turbo timer and enjoy it i say.
With the standard turbo and intercooler anymore then 12psi will just cook the air making the engine more likely to ping (bad) and not give any power increase, I wouldnt recommend leaving it like that with summer coming up.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
