im heading out this wednesday night
this time im getting there in line by 5pm. this time there is no excuse for not getting opportunity to do burnout at end of night!!
sick of this bloody truck doing big boring burnouts?
its time to see some nissan power out there
am not looking forward to hearing the crowd when my engine blows during the burnout
anyway
come on out
cheers, mark
you know damn well !!!! :(
I have...rather richard has....photgraphic evidence !
oh now i remember haha
ben, just dont show me up in the burnout comp!! i hear the hiaces can blow tyres in less than 30 seconds!!!
for f**ks sake you are f**king kidding me!!
just got home and had shower
this morning:
did another oil change
put coolant into the radiator for the 1st time ever (thought it deserved somethinbg better than the usual h20 considering burnouts etc)
changed the rear brake pads
bled up the brakes
changed filter
etc etc etc
and now there's no drags
oh man how depressing.
i am becoming a drag boy. tragic
i'm going to the pub
have a good day boys
depressing
Agreed.
Not working tomorrow, and so was going to venture out.
The Missus was going to have a go for the first time in quite a while now.
Was looking forward to seeing her smash her previous time (and hopefully kick someone's arse in the process).
El Bee
    • Maybe it's time for a M3 F80 LCI, and leave it stock.  Drive it to a shop, sip on your latte with nutmeg whilst it gets serviced and on the way home swing by and grab some chai mix for the evening.
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
