  • Replies 425
Posted Images
IF ANYONE HAS A ISO CABLE AND LAPTOP WITH APPROPRIATE SOFTWARE CAN U PLEASE BRING IT ALONG AS I WOULD LIKE TO CHECK IF MY AFM IS WORKING PROPERLY.
thanks to anyone who can help, please pm me.
I have this...
Your its a stock ECU? I can plug in the cable and monitor stuff....
Ok thanks for that,  all maybe's are being taken off the list cause im not going to buy food and throw it out.
Plus i dont really want to be out of pocket
Thanks again
dw, i'll scoff any remainders down :rofl:
I'm sure we could sort something out for you if folks didn't show.
I mean, You've organised an awesome cruise and we don't wanna see you punished for it
I'm sure a few guys wouldn't mind chucking in a few extra bucks to cover the dirty pikers, I know I wouldn 't.
No worries, added
Not adding maybe/probably's etc cause im not going to buy food and throw it out when people dont show up - im sure you understand
If the maybe turns into a definate, no problem, post up and ill add
Thanks - Steve
Steve just me now...so just the one :D thanks
quick question how does sumone become a SAU member???
Clum membership form:
http://www.saunsw.com/docs/MembershipForm.pdf
Yeah guys i appreciate that, ive decided that if this one goes well ill do another one, if too many people pike, then i wont
Also if i do another one it will be pay over netbank before the day
Which reminds me of something, as gay as this may be, i am actually going to do a rollcall type thing and mark off people - when your marked off u get a stamp. no stamp no food. foolproof!
Hmm looks like they are going to make me work :P Remove me from the list and if I manage to get out of it i'll repost and get added. That way you don't lose out :)
Thanks for the notice, bad luck with work!
The next event will probably be a friday night pizza cruise (Blitz?) hope you have better luck for that one
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
