there is also should be a metal plate behind the excelerater where ya can remove a little screw i think, just one of them on either side of it, that isnt doin much that does the trick beautifully. not sure it should be the same that is in a 4 door.
https://www.sau.com.au/forums/topic/99704-boost-gauge/#findComment-1816040
hI GUYS
i'VE JUST FINISHED THE INSTALLATION OF THE GAUGE AND AM ONLY LEFT TO RUN THE HOSE THROUGH THE FIRE WALL
WherEon the fire wall on r33 do i run the hose. I cant seem to find the hole.
AM i SUPOSED TP DO ANY DRILLING?
Im with wink on that one.... fed mine though the front right guard from the engine bay, nice big hole for ya...
https://www.sau.com.au/forums/topic/99704-boost-gauge/#findComment-1816983
    • As I wait for parts to be delivered, I have managed to procure via a contact a R32 Nistune ECU......for now I just want to monitor what the car is doing but eventually.......who knows where we go 😂
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
    • Good old Orange Park hey... 😛   f**k I miss that race track
    • lo, it was a death trap. Good times. Got any Fatz Drift Day DVDs still available?
    • Yes, overthinking. Many PS reserviors are completely opaque. Our Skyline ones, for example. Have to remove lid, peak inside, swirl the dipstick, try to remember how to read it, etc etc. Normal. Radiator overflows are often sufficiently opaque and scunged up that you can't see the true level inside anyway, and have to open and have a peak. Besides which, I replaced the (massively expensive, even back then) plastic overflow in my Alfa GTV, back in the '90s with a stainless one that I had a good fabricator make up to be dimensionally same-same, that looks remarkably similar to the Bogan's Moroso one above, and I never suffered any particular paranoia that I didn't know how much coolant was in it.
